Battery for a iPhone 5
Battery keeps losing charge. Should I replace or can I fix it?
  • 20 Answers
SOURCE: My fully charged 3g Iphone in the Bose Sounddock it keeps poppin
Try putting your iPhone into "Airplaine" mode. It's possible that the radio frequencies from your phone are interfearing with the speakers in your sound dock.
Posted on Oct 06, 2009
  • 9 Answers
SOURCE: What is the expended battery charge on an iphone.
because one of them its got default lion battery in terms of you need to exchange it or buy a ne w iphone unless you take it to apple and says whats happening sorry
Posted on Jan 18, 2010
  • 197 Answers
SOURCE: unlock 3G iphone keep serching
your battery dying from searching cause, do you have valid sim card installed?
try master reset hold home and top button at same time till you see the apple!!!
if still problem we'll go from there!
Posted on Feb 17, 2011
SOURCE: bought my iphone 5 and am unable to charge using both the plug and computer. however am able to charge using the iphone 4 plug. please help!
your iphone 5 doesn't charge using the wall plug? Sounds like it may be a DOA plug, cable, or phone! I would take it to apple or try to find someone else with the new lightning connector.
Posted on Oct 21, 2012
  • 24 Answers
SOURCE: Generac 12KW questions, will not keep battery charged. I have replaced the 5Amp fuse and battery is not charging
These older units have a hardwired 2 amp battery charger. Usually installed in the generator near the battery or in the transfer switch. If the 5 amp fuse is good the battery charger will need to be replaced. Generac part # 0G8023.
Posted on Apr 09, 2015
My battery on the iPhone 4s has trouble at times keeping its charge, it seems as though there is nothing running in the background. How much would another batter cost?
For a 4S, it really won't be worth the price of replacing the battery. But if you are set on keeping the same phone instead of buying a new one, there are a couple things to keep in mind to keep your phone running well.
1. Turn your phone all the way off and all the way back on at least once every 2 days. This refreshes everything and its amazing how many problems it will fix before they even start.
2. Don't be afraid of letting your battery die every once in awhile. Its actually good for it. Charge your phone all the way, and then let it run all the way down without charging it until AFTER the battery dies.
3. Don't charge your phone until you have to. Charging when you still have 70% will just put unnecessary wear on your battery. A good rule of thumb is to wait until it is down to 20%, or even 10% if you dare.
And it all else fails, spend $15-25 on a lipstick-sized portable charger and carry it with you for those times when you need a quick boost.
Hope that helps!
Apr 14, 2015 | Apple iPhone 4S
Why won't my iPhone 4 keep a charge beyond 4%
It may be the battery or the battery indicator. To fix indicator you need to restore phone in itunes. To fix battery or replace battery - apple can do that for you for 80 bucks.
Sep 21, 2014 | Apple Iphone 4 - 32gb - Black verizon...
How can I replace the battery on my iPhone 5?
What exactly is the phone doing that u think a battery replacement will fix. Not charging,etc?
Jul 07, 2014 | Apple iPhone 5
Battey low very fast
Losts of things such as apps, wifi, bluetooth, etc. will drain a battery fast. Turn these off to see if that fixes the problem.
If you are referring to a battery that charges but loses substantial charge fast then more than likely the battery needs to be replaced as it is going bad.
Jan 13, 2013 | Apple iPhone4 4G iPhone 4
I have had my i phone for three days but will not charge beyond
If the re-chargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 14, 2012 | Apple iPhone 5
Why does my iPhone 4 Battery loses its charge in a few hours
The iPhone 4 has a limited number of charging cycles. The battery in the iPhone 4 is a older type of battery that does not keep well depending on the environment you live in. iPhone 4 is in "end of life" status with Apple and is no longer provides support. There is many cellular stores that will change the battery for $25. The replacement battery's are often better than the ones provided by Apple.
Nov 28, 2017 | Apple iPhone Smartphone
My iPhone 2g is heating up and losing battery even though i am not using it its hotter when i am charging it but if not is not that hot but it lose battery so pass if i fully charger it it will last for...
It's possible that there is a short in the battery cell and/or that you got water in the divice. My experience with Apple is that their customers are #1. Give them a call and they should at least get you to a point of if they will fix it for free or how much it will cost you.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Unlock 3G iphone keep serching for network, has no service and losing battery charge in an hour
Feb 10, 2011 | Apple iPhone Smartphone
I've had an iphone 3G for about a year now, and jus in the past 2 weeks i've had a hard time charging my phone, with either a wall outlet or my computer. i'll find myself spending an hour jus trying to...
Most likely your iPhone battery is dead. If you have the AppleCare and hasn't expired Apple will replace your iPhone battery free of charge.
If it has expired you can pay about $50 (I think) and Apple will replace the battery. If you think that's too much go to Amazon/Ebay and look for an "iPhone Battery Replacement Kit." Remember if you do decide to do the battery replacement yourself. You're voiding your Apple warranty & they won't replace it.
Jan 11, 2011 | Apple iPhone 3G
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
