Question about Pyle Car Audio & Video
I have connected Pyle psbv200t with two leads to sound out but no sound.?
How do i set p the pyle pdwm96?
Is it connected correctly? Try connecting something else to where it's connected and see if you get sound then.
Jan 31, 2014 | Pyle Pro PDWM96 Lavalier Wireless...
No picture on my a Pyle PLDN74BTI
bypass parking brake w/no switch codes
Oct 06, 2012 | Pyle PLDN74BTI Car Video Player
I am thinking about purchasing the Pyle Home PCB3BK bookshelf speakers. Before I purchase, I need to know how they are connected? I have a JVC CD player that I want to connect the speakers to.
Any search engine will lead you to details about the speakers.
http://www.pyleaudio.com/itemdetail.asp?model=PCB3BK
They're passive mini cube speakers. Unless your unidentified CD player has amplifiers and connections for speakers you are missing the crucial middle piece. What were you going to do about bass?
Aug 11, 2011 | Pyle PCB3BK Speaker
Can I connect Pyle PDIC51RD speakers in series.
Yes, everything can be connected in series. Be sure the positive from one speaker leads to the negative of the next so they will be in phase.
Aug 18, 2010 | Pyle Audio Players & Recorders
I have a pyle plttb1 and i have connected with the equlilazer and did not make any sound and after connected directly with the amplifier and make some sound but very low
Just a guess - traditional turntables require a specific PHONO preamplifier to boost and frequency-shape the phono catrdige's tiny signal prior to sending it to conventional Line Level inputs. Get one.
Jul 06, 2010 | Pyle PLTTB1 Turntable
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
My amp
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Nov 01, 2008 | Pyle PLMRA420 Car Audio Amplifier
PYLE PLDF7IN
CHECK TO MAKE SURE THE INLINE FUSES ON RADIO ARENT BLOWN .
YOU CAN CONNECT POWER TO THE POWER OUT LEAD AND MAKE IT COME ON
Jan 17, 2008 | Pyle PLDF7IN Car DVD Player
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
