Question about Hoover Washing Machines
Hoover 700L will wash and drain but not spin. What can I do to fix it?
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
Posted on Mar 16, 2009
barkencoa
  • 3463 Answers
SOURCE: Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
Posted on May 30, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
Why my hoover 700l won't spin
Most likely a broken drive belt. Easy replacement.
Aug 08, 2016 | Hoover Vacuums
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
Hello.
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Thanks.
Feb 19, 2011 | Hoover Washing Machines
I have a Hoover 750L washing machine and it is not spinning now in the washing circle so the clothes are soaky wet. How can I fix this problem
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
Mar 31, 2010 | Washing Machines
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Simpson 700L Top loader washing machine won't spin anymore. It washes fine but when it gets to the spin cycle it wont spin. It drains ok. Any suggestions please?
If this machine is not belt driven, then more than likely is the motor coupler. To give you an idea of this problem follow this link....
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aaron
Jan 24, 2010 | Washing Machines
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
