Question about The Office Equipment & Supplies
Showing error code c3451bizhub 215should last with fuser for how long coz i replce myne september and bringing this error cod,although there was a problem with the electricity,
Sp210 sc543 error cod
might be fuser is bad repair or replace then reset code. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Mar 23, 2017 | Ricoh Office Equipment & Supplies
I have Toshiba e-studio 257 and have an error code C970 on the screen. Can you help me?
C3D2 EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]). C410 Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON. C430 Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state). C440 Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. C450 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing. C4C0 Fuser unit new/old detection fuse abnormality C550 RADF I/F error: Communication error has occurred between the RADF and the scanner. C551 Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed. C570 Communication error between Engine-CPU and IPC board C580 Communication error between IPC board and finisher C5A0 EEPROM communication abnormality (LGC board) C8E0 ADF communication abnormality: The system has to be stopped because the control abnormality occurred C940 Engine-CPU abnormality C970 High-voltage transformer abnormality: Leakage of the main charger is detected. CA10 Polygonal motor abnormality: The polygonal motor is not rotating normally.
These are the error cods list. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 08, 2016 | Toshiba Office Equipment & Supplies
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Konica 7065 with error code F36- 1
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Feb 25, 2010 | Office Equipment & Supplies
Kyocera FS-1920 printer
this error belogs to temperture error
*replace the tharmister (white color componet it comes in fuser unit ) it will work
Mar 17, 2009 | Kyocera Mita FS-1920N Laser Printer
Lanier LD225 copier with a error code 541
All clear huh, wow, what error code do you have sp7-403 1 thru 10 will show you the last 10, a code of 541 thru 548 relate to fuser with the fuser out there is no gap between the hot roll and pressure roll right? -Carl
Dec 25, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Nov 04, 2008 | Samsung CLP-510 Laser Printer
My Xerox B/W Copier XC 1044
When was the fuser last replaced?
Jun 09, 2008 | Office Equipment & Supplies
26 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
