Question about Ovens
We can not set the clock so we can use the oven
Oven is euromaid GT 60
SOURCE: Hotpoint oven clock
1 make sure all oven controls are turned off 2 press & Hold in both the cook period & end time buttons together 3 with both buttons still held in press either the + or - buttons to set the correct time of day 4 Release all buttons simultaneously the time of day is now set.
Posted on Oct 01, 2007
SOURCE: the clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Posted on Mar 10, 2008
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
SOURCE: Gorenje B3350E
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Posted on Jul 31, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
Euromaid stove model CS90S manual
The manual is available on the Euromaid website. Electric Oven Ceramic Cooktop CS90S Euromaid
Link to Manual: http://www.euromaid.com.au/sites/default/files/cs90s_man.pdf
Trust this helps, Alan
Apr 18, 2017 | Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Euromaid oven instructions
Try search engine
Jul 20, 2014 | Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
How do I turn my omega oven europa 60-1 on? I turn the knobs, the electric clock is flashing but nothing comes on?
Can anyone tell me how to turn off my omega europa 60-1 oven. I have put both temp and fan to off but oven fan still going Help please as cannot find isolating switch thanks
Oct 08, 2011 | General Ovens
Panel says F5 and oven does not work
F5 = Watchdog and hardware conflict
Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
Sometimes just unplugging the sensor quick connect and cleaning the corrosion in it fixs the problem. Replace control board (also called ERC or clock).
F5 indicates the control felt a loss of power. I generally check the oven sensor for resistance (1040-1090 Ohms @ 770F). If the sensor is within normal limits, the control is bad.
Replace clock (ERC).
(see the following link) although it can sometimes be caused by a failed oven temperature sensor. The sensor should be checked before replacing the control. It should read about 1100 ohms when at room temperature.
- Kenmore 911.45565791 Electronic Control > www.appliance411.com/data.php?ap=AP3156070
- 911.45565791 Oven Sensor > www.appliance411.com/data.php?ap=AP2023670
Hope helps.
Jul 07, 2011 | Jenn-Air Electric Double Oven
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
I own A Euromaid oven, model 1505 TI Turbomaster. The interior glass has become unattached to the seal that holds it to the metal of the interior door. I want to remove the door from the oven so I can take...
On page 20 of the manual it tells you how to remove the door. The link for the manual is: http://www.euromaid.com.au/site_folders/125/docs/ABCDEF/1505TISSBMSS7_manual.pdf
Dec 14, 2010 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
I have a Euromaid 1505 TI oven. It worked fine yesterday. Today when i went to use it, the display screen is blank and it won't work. I checked the main power switches in the garage, and everything seems...
I have euromaid 1505TI oven, the bottom element was replaced but since then have been unable to bake cakes, bis, etc without them burning,. have tried lowering the temp but still burns. can anyone help me with this and tell me what the prob might be before i get a tech in.
May 15, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
