Question about PRINTER Office Equipment & Supplies
How can i fix an error code of c3451 to printer machine
otacon
  • 1944 Answers
SOURCE: SERVICE ERROR CODE
I am trying to find what that code means. If you want to look for yourself, there are tons of C250 manuals at the following link at Minolta.
http://kmbs.konicaminolta.us/content/support/supporthome.html
Pick category: Office systems
Pick model: C250
Posted on Jan 03, 2008
sir fixalot
  • 146 Answers
SOURCE: Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Posted on Jan 04, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
Posted on Jan 08, 2008
SOURCE: error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
hope this helps
Posted on Jan 15, 2009
DocuSystems
  • 10 Answers
SOURCE: i have code c3451
Power off using left side rocker switch.
Power on while holding utility counter
Press trouble reset.
Cycle power (rocker)
If it comes back immediately you need to replace the fuser.
Posted on Aug 05, 2009
??? ??? ??? c3451
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Feb 03, 2016 | Office Equipment & Supplies
Konica-Minolta bizhub 215 giving c3451 error message?
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
How can i solve the problem of c3451?
May 01, 2014 | Konica Minolta bizhub C250 All-In-One...
What if the machine is showing c3451, what should we do?
Hi Stephen,
This error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
Try resetting it by switching machine off using the switch inside the front door, not the one on the control panel.
This will hopefully reset the error code. However, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Apr 25, 2014 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 350 Error c3451
Hi there.
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have code c3451
Mar 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3451
hope this helps
Jan 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Sep 01, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Top PRINTER Office Equipment & Supplies Experts
murray greenberger
Level 1 Expert
John Hong
John Hong
rfredey
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
