Question about RC Toys
How to charge my nqd rc 7 .5 niccad battery with out the right charger
4 Suggested Answers
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
micromend
  • 748 Answers
SOURCE: Battery, 8.4V 900mAh NiMH 7-Cell. Works with RC Airplane Models: Commander: how long does it take to charge?...
Hi
From the picture this looks like a Firebird product? If you're using the AC charger that came with the product, charging is usually overnight. If you're using a generic NIMH charger then 15 - 20 minutes is normal but its all based on your charger.
Posted on May 13, 2010
  • 107 Answers
SOURCE: Was charging my 2000 RC 51 motorcycle with a
Sounds like you may have cooked the battery - if the charger burned out it is usually from over loading it - the batteries don't like to be over charged - I'd pull the battery and have it checked if its a battery you can top up check the fluid lvl in it it has probably boiled it self dry.
hope this helps
Posted on Jun 03, 2014
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
How can I reset chip on my Makita lithium ion 18v battery
Based on experience I can tell you that it is is generally the temperature/cutoff/individual cell monitoring sensor in charger that dont allow the batteries to take a charge. Once the same condition is detected 3 times by the same charger it considers the batteries to be bad and refuses to accept it. I have 2 batteries that wont charge on one charger but works perfectly fine when i charge it on my other Makita charger so basically there is no problem with my batteries.
I would suggest first you check the voltage of your drained battery by a test multimeter. For 18volt battery if it is close to 18volts 1-2 volts less is just fine! Then there is no issue with your battery. Makita chargers are very expensive hitech which is useless in my opinion the lipo chargers (used in rc hobby) example skyrc are better quality cheaper and does a better job and you can easily charge your makita battery with it as well but this is only recommended if you decide not to go with Makita charger any more. Some basic information about multi chargers for Li-ion battery to follow the safety is make sure you use the right connectors with correct polarity. For 18v volts max voltage should not exceed more than 20.50 and the allowable charge current is 2.7amps also ensuring that batteries dont heatup.
Oct 05, 2014 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Was charging my 2000 RC 51 motorcycle with a battery charger and a battery charger burnout and now I turn the key I have no power I have checked all fuses and none of them are bad you have any suggestions
hope this helps
Jun 03, 2014 | Motorcycles
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Hi
May 11, 2010 | Challenger Battery, 8.4V 900mAh NiMH...
How long do I charge my boat
All depends on the size of the battery and the charger youre using. Standard batteries are 7.2v on these boats pictured. You will have to check the mah which is on side of battery, if its 1800mah and youre charger charges at the rate 500mah you should charge it for 4.3hrs.
Mar 07, 2010 | Hydro Slide Radio Remote Control Hydro...
Looking for a charger/adaptor for a toy RC car
Buy a "universal charger" wall wort. Most will chargs 1.5 VDC to 12 VDC in steps adjusted by a slide switch. The polarity of the tip is switchable from + to -, so be careful to switch the tip to the right polarity for your radio. Try to find one that has close to the same current output that the original charger had. Good Luck,
Longshorts.
Jun 22, 2009 | Columbia Telecommunications Group...
New bright 19.2v nicd battery problem
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Mar 30, 2009 | New Bright Remote Control Toyota FJ...
Toys Logo
48 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
