Question about Canon PowerShot SD600 Digital Camera
Color Accent and Color Swap
I cannot figure out how to use these features. Can someone help me figure this out?
  • 36 Answers
Color Accent:
  • enter this mode
  • point to a color you'd like to highlight
  • press Menu
  • shoot
This will be the only color, all other colors will now be shades of gray.
Color Swap:
  • enter this mode;
  • camera will ask you to input Original and New colors;
  • use Up and Down to select how loose/precise color selection needs to be;
  • point camera to something with Original color and press Left
  • point camera to something with New color and press Right
  • shoot
Everything with the Original color will be shown with the New color.
Both of these procedures are described in the Advanced User Guide, pages 59-63 ( http://gdlp01.c-wss.com/gds/0900001430/PSSD600IXUS60CUGad-EN.pdf )
Posted on Dec 27, 2007
SOURCE:
How do I use the "color accent" feature on my SL202?
Advanced: Color Accent To Shoot with Only One Accent Color (the rest in black and white): Turn the mode dial to SCN. Use the arrow directional pad to select Color Accent. User Guide Press SET to edit the accent color. Point the window at the accent color and press the left arrow on the directional pad to set the accent color.
Aug 09, 2013 | Samsung SL202 Digital Camera
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
How do I use the Color Accent feature on my Canon Powershot ELPH 300 HS? It will only focus on green at the moment. No info in manual.
Once you select the color accent you should see the word " menu" in the bottom left hand corner of the screen with a down arrow next to a picture of a tube of paint. This means hold down the menu button for longer than a second, then you can adjust the color to be accented in your photos. Any time you see the word menu and the down arrow on the screen it means hold the menu button for longer than a second for more options/setting adjustments.
May 05, 2011 | Canon Cameras
My camera was working great, but the last time I used it the color was all washed out. Some things in the picture had color and others didn't. I think it has something to do with the color accent. I...
'Washed out' sounds as if the pictures were over-exposed which could be caused by settings which have been altered, as you said. It should be fairly easy to set the camera to 'auto', which will override any unusual settings in the 'manual' mode and be the simplest way to deal with the problem. Naughty girls!
Dec 11, 2010 | Canon PowerShot SD1100 IS Digital Camera
Manual for ''Canon IXY Digital 210 IS'' Camera Needed (in English)
This is “Digital IXUS 110 IS” manual.
(”Powershot SD 960 IS” is “Digital IXUS 110 IS” in Europe)
hxxp://files.canon-europe.com/files/soft32659/manual/IXUS110is_CUG_EN.pdf
[Changing the Color and Shooting] : page 88 ~ 90
*Color Accent & Color Swap
Jan 21, 2010 | Video Cameras
How can I turn a color photo to B&W and save only one color? Canon Power Shot A590 IS
That's called the "color accent" feature. Press Function button, then select the Eyedropper icon with an "A" beside it. Then press Function again.
Now press the Display button. This brings up a cursor in the center of your screen. Point the cursor at an object with the color you'd like to keep, and then press the left button to select it. Then press display again to exit.
When you're done trying color accent, remember to set it back to Auto by pressing the Function button, then selecting the Auto feature.
Sep 19, 2009 | Canon Cameras
Can't get normal color in video mode.
We just solved this problem! Rotate the wheel button (above the Display & Menu buttons) to see the various option (Color Accent, Color Swap, Compact, etc.) and stop when you get to Standard.
Sep 12, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
949 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
