Time of day clok stopped - Audio Players & Recorders
  • 12,267 Answers
What time was it?
Posted on May 12, 2017
My radio is about 8 years old and from time to time, the digital display does not work. Is the clok useless??
U might just have a bad connection inside that intermittently opens.
Those displays can and do fail. Often as time goes by they get dimmer and dimmer.
Mar 09, 2016 | Audio Players & Recorders
How do I re-set my CLOK TCR338 to not read in military time?
heres an answer another question had that might assist u in some way:
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Dec 05, 2014 | Watches
My service light came on, I have 167,000 miles on 2001 Jetta TDI. What service is needed
160.000-engine oil and filtr replace
brake pads and disck heck condycion posible replace
time belt replace
check level oil gearbox
swith off service light:
Switch ignition off
Press and hold buton ( 0.0 ) right said under spido clok
Switch ignition on
Press buton ( hmin) left said under rev-coutner clok engine
The new service interval is displayed
Switch ignition Off
SERVICE LIGHT OFF
finish Good Look
Aug 10, 2011 | 2001 Volkswagen Jetta TDI
How to set clock clok tcr368
Setting the CLOK TCR368 is done by having the unit:
Turned OFF - The power button is located at the top left face of the unit.
Press and hold the CLOCK/DISPLAY/PLAY/PAUSE button for at least 4 seconds. (It is located to the right of the power button at the upper left corner of the unit.) Do not let go of the button.
While holding down the CLOCK/DISPLAY/PLAY/PAUSE button, press the HOUR and MINUTE buttons to the correct time.
Release thethe CLOCK/DISPLAY/PLAY/PAUSE button.
The backup battery is to keep the clok circuit running in case of a power failure and can't be used to power the radio.
With the unit OFF, press and hold the FUNCTION button (located between the ipod slot and the snooze button) for at least 2 seconds. The display will flash either 12 hour or 24 hour depending what mode it is in.
Release the FUNCTION button and press it once to change the mode.
Press again to cycle between the 12 hour and 24 hour mode.
When the display indicates the mode you prefer, simply wait 2 seconds for the clock to go into that mode without pressing anything.
Sep 20, 2009 | Digital Products International Clok Smooth...
Cannot figure out how to set favourite radio stations on my Clok
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
Dec 25, 2008 | Digital Products International Clok Smooth...
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
I can not figure out how to set the times, or the alarm for my new Clok Smooth iPod Docking Clock Radio - TCR368 manual. it did not come with a manual or instructions of any kind.
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Trying to set the timing on this car with a new engine,please help.
timing belt replace v6 engine turn the crankshaft clok wise slowly and make sure that nothing is stoping it for turning, until the key on the mark reach 12 o clok (TDC) the piston no 1 is att the top dead center .if the piston stop before reaching the top dead center ,,,,,one valve or two are open and the cam have to be ajust so dhat valve can close up,,,,,, so after the crank alignement ,the two cam marks at LEFT CAM 2 o clok right cam10 O CLOK ,,,note the belt slack must be on the tensioner side
Aug 03, 2008 | 1990 Lexus ES 250
32 people viewed this question
 Grubhead
Grubhead
