NUM AND LETTERS ON PRINTER CONTROL WINDOW BLINKING C4EB
Keyboard letters are numbers and numbers are letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
Asus Eee netbook how to disable the numerals when typing letters
Hello, if you're typing numbers instead of letters when you press some keys then you have the digital
lock or num-lock enabled, you will need to turn off num-lock to type normally.
To do this, press Fn + Num LK
Hope this helps, thanks for using FixYa
Aug 30, 2011 | ASUS Eee 4G Notebook
Key board of Samsung Notebook R470 is malfunctioning. When some letters are pressed numbers come out instead of letters. Example is when letter i is pressed number 5 comes out. Whats wrong with the...
Oh yes, I have had this happen before and it sucks.
This problem is usually just due to having Num lock on. Try pressing the num lock button on your keyboard and see if this makes a difference. In the smaller notebooks and netbooks they combine the numbers and letters onto the same keys using num lock to distinguish the mode.
I think on your model the num lock button will be towards the top right of the keyboard. You may also have to press the FN (function) button at the same time, but I am not sure.
Also there should be a small led that illuminates or goes dark to inform you when num lock/scroll lock/caps lock are enabled/disabled.
Aug 28, 2011 | Samsung Computers & Internet
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
Numbers appear w7hen i type certain words 7how do i solve t7his
You probably have the Num Lock on. The letters affected by the Num Lock are u, i, o,j,k,k,l,m.
The Num Lock should be located at the top right of the keyboard and is usually in blue letters although with some keyboards its lettered white. Hit the Num Lock key and that should resolve the issue for you.
Regards.
May 26, 2010 | Sony VAIO PCV-W600G PC Desktop
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
Where is num lock button on Gateway MA7?
Fn+Scroll will toggle the Num Lock
The ison on the keyboard is a purple Lock with the number 1 inside.
Jun 07, 2008 | Gateway MX6920 Notebook
Keyboard
Can you please clarify this
  1. Do you keys not respond at all
  2. Do you get numbers when you want letters or otherwise letters to numbers
  3. Or does it respond only in one mode numbers only or letters only
My suggestions
  1. If its situation 1 then try reastarting your machine, and unblocking the num lock and vice versa
  2. If its situation 2 just try unblocking num and blocking back by turning on or off the num lock, its just num lock or FN + Num lock in some PC
  3. If its situation 3 just restart your computer.
Mar 25, 2008 | Acer TravelMate 361EV PC Notebook
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
