Ran diagnostics at the end of cycle display shows 15. what does that mean
2 Suggested Answers
  • 9472 Answers
SOURCE: wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Posted on Oct 18, 2012
Cabrio. Why does it stop during rinse cycle?
Possibly the pump has something clogging it and it takes too long for the water to drain out therefore causing the internal time to take too long. Remove pump and see if its clogged.
Jul 26, 2015 | Whirlpool Washing Machines
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
F:17 error code Bosch Maxx5
I imagine if you could replace that bad coil you would solve your problem. No doubt you'll have to replace the entire valve though. Let me know if you need assistance finding the part. Don't forget to check eBay for the part too. Good luck.
Jan 20, 2013 | Washing Machines
Wfc7500vw spins but not at high speed on final spin
Oct 17, 2012 | Whirlpool WFC7500VW Washer
Washer displays Ld and won't drain. won't restart or anything. kenmore oasis
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem.
You can use a diagnostic test to start the drain pump. To start this diagnostic test, press the following keys in this order: SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL. The display should show "dt" after this key dance. Press the JEANS/COLORS key to start a 60 rpm spin and drain test that will terminate after 40 seconds. Listen for the drain pump. It should be running during this test. Also listen for unusual noises from the pump that could indicate that it is clogged. You may be able to drain the water from the washer using this diagnostic cycle depending on the severity of the clog or failure. If not, you may need to manually remove the water. If you are able to safely access and clear a clog in the drain pump or drain line, you may be able to repair this problem yourself.
Jan 07, 2011 | Kenmore Washing Machines
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Engine code 95 jeep grand cherokee lerado
12 is a battery disconnect within the last 50 start cycles and 55 means the end of the diagnostic cycle.  Basically the computer found nothing wrong. The 12 code may seem incorrect if you haven't disconnected the battery recently, but from my experience the 12 code shows up almost all the time regardless.
Dec 16, 2008 | 1995 Jeep Grand Cherokee
1993 Cadillac Deville Phantom Codes
ECM Output Cycling
This mode can be initiated after "E.9.5" is displayed on the "Fuel Data Center". The display of the "E.9.5" can be reached by depressing the Hi button while Code ".7.0" is displayed. The ECM output cycling mode, Code "E.9.6." turns the ECM's outputs on and off. To enter the output cycling mode, proceed as follows;
The engine must be running.
Turn the cruise instrument panel switch to the on position so that the cruise control outputs will cycle.
Turn the engine off and within two seconds, turn the ignition on.
Enter the diagnostics and display Code "E.9.5".
Depress the accelerator pedal (throttle switch open) and release it (throttle switch closed). The ECM output cycling mode begins as the display switches from Code "E.9.5" to Code "E.9.6."
It is possible to leave the ECM output cycling mode at any time and return to ".7.0" by clearing the ECM and BCM codes. If the display does not advance to Code "E.9.6", refer to Code "E.7.2" of the switch test.
The output cycling mode will end automatically after two minutes of cycling and the display will switch from Code "E.9.6" to Code "E.9.5".
The outputs will cycle on and off every three seconds until the two minute automatic shut off occurs. The only exception to this three second cycle is the cruise control power valve which cycles continuously. If additional output cycling is desired, recycle the throttle switch.
Oct 13, 2008 | 1993 Cadillac DeVille
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
