I have an error on iRC4080 colour copier E000001-0102
Colour not working
have you check toners to see if they are not empty ?
Apr 21, 2013 | Ricoh Aficio 2232C Color Copier
Canon irc4080 error Eoooo12
You need re-install the Delivery Feeder Unit
follow the step on
http://support-th.canon-asia.com/contents/TH/EN/8200281600.html#2
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Canon imageRUNNER iR C4080 Color Copier
How do I print the configuration report page on the irc4080?
If your looking to do a configuration report of the copiers internal settings you must be in service mode level 1 and under Copier>Function choose Misc-P then P-Print. Now push OK and within 30 seconds the machine will print the internal configuration. You can do this with all newer Canons.
May 27, 2011 | Canon imageRUNNER iR C4080 Color Copier
Error 05 colour ink light flashing
Use only original cartridge to solve this error code.
May 25, 2010 | Office Equipment & Supplies
I got this error code: E000007-0001, what is it and how do I fix it?It says turn machine off and then turn it on and off.
press star than #2 and #8 at the same time look for funtion and clear, press the error than clear power machine off than on see if that clears it
Jan 17, 2010 | Canon imageRUNNER C5180 Color Copier
Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 10, 2009 | Minolta Office Equipment & Supplies
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
