Question about Garmin nuvi 200 Car GPS Receiver
My screen now says "No detailed maps found that support routing. The nuvi cannot be used without them". What happened???
  • 1 more comment
  • ebcr Jul 25, 2009
    I tried that, and the only thing it asked was "Do you really want to change all user data?". I chose yes. I chose my country, time zone, language and about registering product. Then I received same message about "No detailed maps......
  • ebcr Jul 25, 2009
    I tried resetting the nuvi 200 be holding down the right lower corner of screen while owering up. I cleared user settings etc. Message is still appearing: No detailed maps found that support routing. The nuvi cannot be used without them.
  • ebcr Jul 25, 2009
    That did the trick. Thanks so much for your help! I was ready to toss in the trash!
  • 339 Answers
If you registered the unit, then go to the Garmin website, login, and get your unlock code then follow the instructions below:
Windows computer:
1) Right click your mouse on the desktop of your computer, then select "New", then select "Text Document". This will place a new text document icon on your desktop
2) Double click on the newly created Text Document icon on the desktop to open the text document window
3) Copy the above unlock code into the document.
4) Click “File”, then "Save as"
5) In the "Save as" dialogue box, change the file name to gmapprom.unl
6) Change the “Save as type” to "All files", then save the document and close it
7) You should see the file "gmapprom.unl" on your desktop as an icon
8) Right click on the gmapprom.unl file on the desktop and then select “copy”
9) Plug your Garmin device into your computer and then open “My Computer” or “Computer” This will show the devices attached to the computer
10) Double click on the Garmin or Nuvi drive to access the files on the GPS.
11) Right click on the Garmin folder and then select "paste" to past the gmapprom.unl file into the Garmin file folder.
12) Safely disconnect your Garmin device from the computer electronically before disconnecting the cable.
13) Disconnect the USB cable, then power the GPS on…..
If your unit is not registered, you can try registering it and then do the above or just give Garmin a call and they'll get you the code based on your serial number.
btw, it won't help to ask for an unlock code here as the codes are unique for each device based on serial number.
Posted on Jul 25, 2009
Hi there
If your GPS just starts to display the "No detailed maps found that support routing. The nuvi cannot be used without them." and you did not update your maps you should try to reset your GPS.
Do this my pressing down the lower right corner of your screen and turn on your GPS. Keep the corner pressed until you see a Yes/No dialog box asking you if you would like to reset your GPS.
Answering Yes will reset your GPS and should fix the problem if you did not try to update the map.
Regards
SOURCE: No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Posted on Jan 24, 2009
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin Nuvi 205W tried to download map and now
See the link Here
Regards.
Posted on Apr 16, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
madguy1089
  • 21 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Posted on May 27, 2009
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Was working fine and suddenly deided to lose maps. message on screen says "no detailed maps found that support routing. The nuvi cannot be used without them." What happened and how do I GET THEM BACK. ...
Call up Garmin and have them walk you threw a trouble shooting procedure. It sounds like your unit has erased itself by no fault of yours. Garmin will replace it once you get ahold of them. There is not anything that we can do without thier support.
Nov 25, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
