Question about Amana Refrigerators
Mullion heater connection for Amana 84" Integrated bottom mount refer model B136CAR3 mfg P1318402W.
I need to hook up the mullion heater that is under the freezer, component P/N 12401301. But I cannot find the mullion heater connection point. According to the specs it's installed in the foam and not wired from the factory and is for service purposes. The reason for this is that the water from the defrost cycle re-freezes and clogs the drain hole. Eventually the ice gets almost an inch thick and it's SOLID. The freezer drawer cannot open, so I have to thaw it all out and pry it open. I've done this dozens of times over the years! The service tech never figured it out. But with help of my boat-refer-expert brother we found the solution at the high level. Devil is in the details. According to the instructions: make a slit and peel back the white vinyl harness sleeve that goes to the water valve, pull out two wires (black and white) that aren't connected to anything (yet). Then "locate the mullion heater leads at the left side of the cabinet and connect to the back and white leads". Then Wrap vinyl sleeve with electrical tape to seal the slit. OOOOOKAY.... I found the unconnected leads in the harness that goes to the ice maker water valve. They have male bullet style plugs and clips (a little corroded) but I cannot find anywhere to connect them... Is left side of the cabinet as viewed from the front or back? The main harness is on the left rear area. And if I make the slit long enough (which is very difficult, then the wires could make it back there. If I only could find where the mullion heater's connectors come out. Of course the wiring diagram only shows the mullion wiring as optional and not connected to anything. I really do not want to lay this 500lb (at least) beast on it's side. It already fell on me and my daughter, but a countertop and pallets save us. This refer has been nothing but a pain to deal with ever since I bought in 2001. I don't want to get rid of it, since it has custom wood panels that go with our kitchen, and I fell on hard times (due to illness) and cannot afford a new one. It fixed many things on it already. Such as the problem where the relays weren't soldered properly onto the main logic board, which fixed the non-defrosting problem and the freezer fan not working. But now the drain hole plugs with ice. So I read that many freezers have a 5W to 20W heater that runs all the time to keep the hole from freezing. Especially if water gets in the insulation under the floor of the freezer. Anyway, can anyone tell me how to find the connections to the mullion heater? Is it in the outside-rear channel up back of the refer? it's pop-riveted on. Thanks! Scott
  • 770 Answers
SOURCE: Ice Maker installation
the im will only fill when the fingers are at the 12 o;clock position TO cycle your IM ...remove the cover and insert a jumper wire in the T and H holes once you hear a faint click or after 15 sec remove the jumper the im will continue to rotate when it hits (the fingers) the 12 o'clock spot the fill valve is energize for 7 sec then the finger come to rest and stop at the 2 o'clcok position..Let me know if you need more info
Posted on Feb 22, 2008
  • 828 Answers
SOURCE: I have two whirlpool refrigerators.
Under the cabinet in the back is a drain tube with a loop for air seal. this loop will sometimes become plugged. Clean it and it may resolve your problem. I use a small section of automobile speedometer cable as a mini roto rooter.
Posted on May 03, 2008
  • 154 Answers
Well black wire should be your earth wire. But are you going from window motor to car or from car to window motor?
Posted on Jul 28, 2008
  • 1462 Answers
SOURCE: Drain hole plugs with ice
this is a perpetual problem due to no drain heater being fitted. what may help is to run some pieces of copper wire from the defrost heater and have them into the drain hole. enough heat may be conducted to cure it
Posted on Sep 18, 2008
  • 943 Answers
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Posted on Sep 27, 2008
I need to replace a spring in the mullion on my fridge. Anyone have a link to the repair manual for instructions on removing the mullion?
Use your model number and order the mullion assembly before you dismantle the old one... Looking at the new part will show you how and what to remove, in most cases... Samsung Refrigerator Spring DA81 01345B cannot be replaced on it's own. You will need a part more like this: DA97-06417Q, Order it with your model number to ensure the correct fit.
May 25, 2016 | Samsung RF30HDEDTSR
Why doesn't the mullion heater snap back after I open the door?
Hello Al;
My name is Peter. I am a retired field service refrigeration technician.
All is good. Your Mullion heater snaps back when you open the door because it is spring loaded. When you close the door the springs ensure that the mullion is flush and tight against the front of your unit.
The purpose of the mullion heater is to provide low heat to eliminate any moisture (condensate) created by the warm air in the room.
May 19, 2015 | GE Refrigerators
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
Dec 23, 2014 | Dometic RM2852 Refrigerator
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Condensation on ceiling of refrigerator (under the freezer). Ice crystals in small crate. Hot, humid weather now. Thanks! Hana
wipe down the moisture and if there is a switch which says "saves energy" or "reduces
moisture" then turn it on. (this is a mullion heater to reduce condensation) Also check
door seal for gap (this can sometimes be adjusted by light heating with a hair dryer
or replacing the seal itself). Hope this helps.
May 29, 2011 | Amana Refrigerators
Moisture control not working
That controls a heater (Called a mullion heater) that must be replaced.
Dec 08, 2010 | Whirlpool ED2FHEXN Side by Side...
We have an Amana side by side SXD22. The center
That is where the mullion heater is located.
Apr 06, 2010 | Refrigerators
Subzero 550
Call a servicer to determine if a mullion heater is called for.
Aug 02, 2008 | Sub-Zero Bottom Freezer Refrigerator
Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Jul 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Freezer working but refigerator not...
Mullion heater is not the problem. If the refrigerator is not cooling look to the freezer compartment for your problem. Air from the freezer is used to cool the refrigerator(s) section. If the freezer coil frosts up it stops air circulation to the rest of the system. Although you may think the freezer is working properly it may have a defrost problem and will show up there also. Look for signs of frost on the back wall of the freezer as a sign of the coil freezing. The mullion heater is designed to put out just enough heat to stop condensation between the outside temperatures and the inner compartmant temperatures. If the inner compartment is warm the heater will seem warmer than normal.
Jun 26, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
