Question about Samsung Televison & Video
My bio vision Samsung tv's yellow light come on after our power was off. the yellow light do not want to go to red so that I can put the tv on as usual.
  • 308 Answers
SOURCE: philips tv 30pw9815
More than likely it is a power supply type problem and could have multiple components bad. They are no fun to work on either, so I would either have it serviced (Expect $250-400) or replace it as the price of this size set has decreased dramically the last few months. To get a feel for what brands are more reliable, check out the last few issues of Consumer reports at your local library.
Posted on Mar 12, 2007
SOURCE: 8525 Red Light
Take the battery out then plug in the phone. The light should turn red, then reinsert the battery with it still plugged in. It should turn orange and start charging.
Posted on Jun 27, 2008
Ecollier2012
  • 3459 Answers
SOURCE: picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 21, 2010
  • 1536 Answers
SOURCE: Samsung R700 wont switch on, powers up but nothing happens...no hdd or bios lights
Remove the battery, hard drive, optical drive and memory. Install a known-good memory module. If the system starts up and complains about not finding a boot device, or just displays a blinking hyphen, one of the devices you removed is bad. Put in the battery and see if it continues to run. Shut down the system and reinstall one of the memory modules. Try it again. If it still starts up, shut it down, remove the battery again and put in the other memory module in place of the test unit.
Do the same with the remaining components (shut down and remove the battery before installing each part). Save the hard drive for last so you don't have to worry about messing up the operating system with the forced shutdowns. When the system fails to start, you've found your bad part. (If it won't start with all of the parts removed and test memory installed, the logic board has a failed part on it.)
Sometimes removing and reseating a memory module will fix the problem - that would happen automatically with the procedure I just described. Your User's Manual should have the instructions for replacing memory. I'd give you a download link and page number, but the Samsung support website says the SCH-R700 is a cell phone. Use the complete model number from the bar code sticker on the bottom.
Posted on Nov 24, 2011
elitecgdwolf
  • 744 Answers
SOURCE: Hi my bio vision samsung tv orange standby light wont go away so i cant use the tv how do i solve this problem
Samsung
Official Samsung support page
Posted on May 12, 2015
RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Jun 01, 2010 | Lorex SG6153 / Weather Resistant Mini...
Picture has ''double vision'' with red.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 20, 2010 | Televison & Video
Where can i get the right cable to put my recorded vidio on to my tv to whatch?
It will depend on the Make and Model of your TV set.
If you are using an Analogue TV or a Video Player/Recorder, it will have Line IN and AV IN connections (these are Yellow (Vision), Red (Audio) and White (Audio).
You can download the Manual for your camera from link below :
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=VP-W60
Page 14 lists the components that came with and are available for the Camcorder.
Page 50 contains the instructions for connecting the Camera to the TV or Video via the cable that came with the camera or a purchased SCART cable.
Page 60 contains the Specifications for the Camera and the cable type is listed under Connections section (Video Out and Audio Out).
NOTE: Not all digital TV's have the RCA connections. However, some do.
I hope this is helpful. Regards,
Feb 10, 2010 | Samsung VP-W60 Camcorder
My TV has horizontal lines (about 5, evenly spaced apart) and the right side is blurry, almost double vision happening..
If you are using a component connection just swap the green and red cables on both sides.
Put the red on the green and vice versa.
Or just change your cable and put a new one.
Jul 28, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Bios don't boot on p7n platinum sli
check the voltage on the power connector going to the hard disk.
it should have 12volts in red and black wire and 5volts on the yellow and black wire.
the main problem the optical and hard disks can't be recognized is the low voltage supply the drives gets.
Apr 13, 2009 | Intel Motherboard
How to hook up wii to surround sound
Put all the wires to the tv. Now you need another A\V cable (yellow, red, white) only use red and white from, audio out on tv to audio in on surround system and set it to TV. OR Put the red and white from Wii to surround system and the yellow to the tv. this way you have to use surround to hear it. The other way you can use the tv or both. The first way is ideal if you have an extra cable.
Mar 15, 2009 | Nintendo Wii Console
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
New Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Aug 28, 2006 | Sceptre X37sv-Naga 37 in. LCD Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
