Home remedy for cleaning sand in pool filter
Can i use bleach or baking soda
  • 9,043 Answers
Replace the sand
Posted on May 12, 2017
Are there any at home remedies to making my own dog shampoo?
Believe it or not, baking soda is your solution. Simply sprinkle some baking soda onto your dogs coat and rub it in with your hands. The make sure to give your dog a good brushing. Baking soda is great because it is inexpensive, will not irritate your dogs skin and it neutralizes odors.
Aug 15, 2012 | Pets - Others
How do i remove black mold on gasket
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire ATF6000ES Front Load Washer
The water smells bad as if it is not draining correctly. Is there a water filter that needs to be replaced? How do I clean out this washer to get it smelling nice?
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps.. Please post back if you need mor information.
Daniel
Nov 26, 2010 | Bosch WFMC 3200 Front Load Washer
Mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG tromm mold smell.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps...
Daniel
Sep 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
My filter is returning green slime to the pool as fast as i vacumn it up.I can see it being pumped back in the pool.Why is my filter not working?
It could be that there is algae growing inside the tank of the filter. You may want to vacuum to waste to get the algae out of the pool and clean out the filter. If you have a Cartridge or DE filter, you will need to do an acid bath for the grids. Take the internal parts out of the filter and clean with bleach water, use bleach water on the tank also.
If you have a sand filter, you will need to empty out the sand, clean internal parts and tank with bleach water then fill with new sand.
Jul 14, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Pump is running high keep shocking it, had algae, cleaned it out, back flushed several times, cannot figure out why it's still running high? (unsure of brand)
DE filter? If so then you need to give the filter an acid bath to purge the dead alge from the filter (Fingers, Grids or Discs). Go with 1part muriatic acid to 3 part water. Let soak overnight. The water should turn almost neon green.Rinse off and reassemble. SHould be Good to go. DE and Cartridge filters should be given an acid bath once a year.
Jun 30, 2009 | Pentair Kreepy Krauly Inground Automatic...
Clean clothes that smell bad
Peace,
ngafm at your service!
You may have a small amount of water or lint lift in the machine somewhere that is not completely dumping out !
This is sometimes common on front loaders! Or the pump is weak!
I tell my customers to try running the washer without clothes once a week with hot water and a 1/4 cup of bleach!
. BUT the first load you do after this must be white in case there is a drop of bleach left in the system, that it does not spot bleach a white spot on your colored clothes!
If not this does not remedy the situation you will need hands on service!
please rate me here at our site before you sign off!
Thank You!
Sep 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Bad Smell
you might ry removeing hte rear panel of freezer. gain access to the evapotator area, thats where the fan thatcirculates air is as well, if the smells stillback there washing the inside wont do anything. once fully exposed i would saturate area with an odor nuetralizer . I use odo-ban. and be sure to pour asolution of baking soda and water downt the drain assy (under the evaperator) that will allow the baking soda to reamin in the lower drip tray long after teh eater evaporates. once refrig gets vcold again the smells generrally disapate anyway
Mar 09, 2008 | GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC...
Washing Machines Logo
Top Washing Machines Experts
