Question about Garden
When I kick the deck in gear the governor jumps wide open and will not go back unless I idle the motor down.
This is on a Kawasaki motor and it only does this when I put the deck in gear.
  • 3 Answers
SOURCE: motor runs wide open but no power from generator
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Posted on Dec 17, 2008
  • 50 Answers
SOURCE: 2002 Dyna wide glide. Will not IDLE
not running for a year! You have a varnish buildup in the low end circuit of the carb. You will need to remove the carb and do a full teardown of the carb to properly rectify this problem. SOMETIMES we are able to free up the passages by putting SEA FOAM cleaner in the tank , fill her up with fresh fuel and ride through the tank and it will clear up. SEA FOAM can be purchased at an auto parts store and is sometimes very effective. 1/4 cup to full tank fuel.
Posted on Jul 14, 2009
  • 4565 Answers
Sounds like you've got a vacuum leak somewhere. Either your intake seals or the carb seal is leaking air. Have you replaced the air filter housing? On the Evolution and later engines, the carb is designed as a "spigot seal" type carb. In other words, it just pushes into a seal instead of bolting on like the older carbs did. This means that the carb has to be aligned correctly or an air leak can occur around the seal. The air filter assembly is what holds the carb. into the seal and aligns the carb.
If you haven't messed with the air filter assembly there is one other thing that I've seen cause this problem. Your bike has two vacuum operated devices on it. One is the VOES switch and the other is the fuel petcock. The VOES switch is part of th igniton system and the petcock is the fuel valve on the fuel tank. The vacuum comes from either the carb or the intake manifold and is routed to the devices by a vacuum hose. Make sure this hose in connected to all three locations and has no holes in it. The vacuum hose to the petcock is on the backside of the petcock and the VOES is located on the bottom of the frame top tube under the fuel tank near the carb.
I have seen the vacuum operated petcock cause a vacuum leak in at least one occasion. Normally, when they go bad they just shut the fuel off to the carb and the engine won't run. But, I did have one that caused a severe vacuum leak and the bike acted exactly like you're describing. I took the petcock out of the tank. Drain the fuel first, not easy to do with the petcock being vacuum operated. I got a large funnel and held it under the petcock while I slowly unscrewed it. Once you have the petcock out, you'll see four small screws on the back side of it where the vacuum hose connects. Remove the screws and check the diagraphm behind the plate. Be careful, there is a small spring behind the plate. Take the petcock apart carefully so you can remember how to properly reassemble it.
Personally, I would eliminate the vacuum operated petcock and replace it with a high quality manual operated petcock. Like I said earlier, if they malfunction they usually shut the fuel off to the engine. There you are, a full tank of fuel but none to the engine. I'd replace it with an original Harley unit for a 1995 or earlier bike or a high quality aftermarket unit like a Pingle.
You need to find this problem before you ride the bike too much. The lean mixture resulting from a vacuum leak will cause the engine to run very hot.
Posted on Oct 20, 2009
  • 2468 Answers
SOURCE: the governor is stuck wide open. How do you fix
have you gotten something stuck in the throat of the carb where the throttle butterfly opens and closes to control speed? check this,then check all moving parts on the carb and especially the governor spring that its not caught on something
Posted on Mar 31, 2010
SOURCE: 20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Posted on Apr 02, 2010
I have a briggs model 407777 that was idling up and down from near top range to bottom. Found some dust in the carb intake and decided to cliean the carb. When removing the manifold/ carb, I took loose...
These can be tricky, but your on the right track. With throttle set on high (engine off), turn governor linkage in the same direction that opens throttle valve in carb wide open, then turn the governor rod in that same direction then tighten bolt on governor arm. This is a static setting. The high and low idle is most likely a dirty carb so assuming the carb is now clean your idle should be better. Hope this helps. Good luck!
Aug 12, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Will not idle
Reconnect the governor rod back on to the carby throttle butterfly correctly. When stopped the lever will hold the throttle wide open and as it starts the lever pushes /pulls the throttle closed to the idle stop screw
May 31, 2013 | 5.5 HP GX160 Engine
Honda gx160
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
2002 sabre lawn tractor runs wide open cannot idle down
sounds like the governor gear is striped you need to open the engine to replace it
Jul 07, 2012 | John Deere Garden
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
Motor is running eratic up and down under load
One of the most important parts of your engine is the engine governor. An improperly adjusted governor can shorten your engine's life. If engine speed is not controlled, the engine will destroy itself. Never run an engine over speed, especially without a load attached to it. Even for a short period of time it can cause catastrophic failures, like blowing the magneto magnet into 100's of little pieces. Over speeding is something that needs to be taken care of immediately, because it can be a real hazard with metal coming loose at high speed. This page will explain how to adjust the mechanical governor on Briggs and Stratton and Tecumseh Engines.
First, let's understand a little more about governors and why they may not be working right:
Most complaints about governors fall into two categories:
  1. Engine runs too fast or too slow.
  2. Engine surges or hunts.
You should do an inspection of the governor linkage and spring before trying to solve either of these problems. Make sure everything is operating freely and the spring is not damaged or stretched. Also, check the governor static adjustment to see that all free play has been removed between the spindle and carburetor. The best way to do this is to move the throttle from idle to full open and note the way the governor shaft moves. If it goes clockwise, then loosen the clamp screw and with the throttle wide open turn the shaft all the way clockwise and re-tighten the nut. Make sure the throttle moves from idle to full open freely after making the adjustment. Refer to the engine repair manual for exact adjustment procedures.
After you have made the above check, restart the engine and see if the governor now operates correctly. With the engine at idle, move the governor lever with your finger to open the throttle and it should push the arm back toward idle if working properly. One way to do this test is with the governor spring removed. If it still over speeds or has no push toward idle, you probably will need to have the internal parts checked inside the motor or recheck the static adjustmen
Oct 07, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I had to replace my governor gear, it shattered in 9 pieces for I don't know why, but i replaced it. The problem I am having is I put it together lined up the dots on the cam and crank gears for the...
It is not internal to the engine unless that run-away condition is why you initially had to replace the governor gear.
Did you get all the springs/rods/throttle cable back where they go ? That's the first thing I would check. I wouldn't tear into the engine for the dots. It's not timing. They go together as you said. It wouldn't have cranked if they were off.
Make the adjustment back to where you started before the run away problem and see if it changes.
Mar 26, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
