Question about Dishwashers
Nobel dishwasher cannot fit dinner plates. Can the top shelf be adjusted ?
kachbibi1
  • 979 Answers
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Posted on Jan 17, 2009
  • 423 Answers
SOURCE: DISHWASHER TOP SHELF IS SQUEEKING AND STICKING.
One approach would be to apply plumbers grease to the wheel (simple) axles turn on. It would be if you can pull the wheels, apply the grease and reassemble the wheels. The plumbers grease can be bought in a tiny tin at any real hardware stores.
Longer term fix would be to replace the wheel assemblies with new/replacement parts.
Posted on May 26, 2009
smokenic
  • 49 Answers
SOURCE: height of top shelf to low for plates
sorry but that can only be remedied by a different unit
Posted on Sep 19, 2009
onthejob5130
  • 640 Answers
SOURCE: My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Posted on Oct 10, 2009
  • 457 Answers
SOURCE: Normal dinner plates hit the top washer arm in Bosch dishwasher
TRY TO ADJUST THE FINS IN THE BASKET TO SIZE PLATES . THE MANUALLY RECOMMENDS HOE TOLOAD DISHES.
Posted on Feb 28, 2010
Can I use my Triciry Bendix dishwasher DH101 if I remove the top. It needs more clearance below the worktop. When I remove the top there is a material, not a solid top.
Listen to hear if dishes are rattling against each other. Cups should be loaded only in the top and care to keep each cup separated from other. Chipping usually will occur when dishes are close together and in contact. The racks are rubberized and would be very unlikely the source.
If the feet are adjusted so the machine will not rock it would be unlikely that the top on or off would have any effect.
The upper shelf is adjustable up or down. Suggest locating upper shelf to the up position.
TRICITY BENDIX Dishwasher
Hope this helps?
Dec 06, 2016 | Dishwashers
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 | Dishwashers
Dinner plate stops arm rotating, plates must be able to go in. why is the arm hitting the dinner plate.surely you must be able to wash your dinner plates in there, from tray to arm is 250cm.
on the topshelf of the dishwasher there are 2 lots of slide wheels . these are to set the shelf at different heights they should be on the lowest wheels to give you the maximum distance between the bottom tray and the spinning arm
Jul 30, 2011 | Dishwashers
My standard size dinner plates are too tall, the rotating part is catching the plates
Some machines have height adjustable top shelf.
Should be couple of clips on side of rack to raise / lower.
Other than that you will have to get smaller dinner plates.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Water spinner hits dinner plates and cannot turn. i can see no way to adjust the height...my dinner plates are average size i didnt have a problem with my other dishwasher.
Check the side left & right side. There should be an adjustment. Pull the rack and observe. you might have to select the lower rails.
Refer your user manual.
May 24, 2010 | Dishwashers
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
Feb 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Height of top shelf to low for plates
Sep 19, 2009 | Whirlpool 24 in. DU920QWD Built-in...
Our dinner plates hit the rotating arms of the jets. We have checked the manual and we are loading correctly. Just doesn't make sense.
Solution - there are 2 sets of rollers about 2 inches apart. You just click off the stoppers at the end of the sliding arms on the top shelf, take out the rack and put it back onto the higher set of rollers!!!
Jun 30, 2008 | Hoover Dishwashers
Dishwashers Logo
Top Dishwashers Experts
