My pedrollo surface water pump of 0.5hp is humming only but not running,what do i do?I put a new capacitor of 25 microfarads,power is available.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Heating & Co... Master
  • 453 Answers
Pump is bad .replaced
Posted on Dec 19, 2017
  • 12,208 Answers
I would try replacing the cap first. does the motor turn at all if you try by hand?
Posted on May 12, 2017
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    My water pump stopped working
    More details are required to analyze the problem. Is there water available to the pump, does it run but no water etc. etc.
    Jun 21, 2016 | Pedrollo PJ3015-CF N/A 1-1/2 HP High...
    My pedrollo pump, pumps water for a while and goes off by itself. i have put it off (electric switch) and wait for time say 5min and put it on again. it works for a while and goes off again so i have to do...
    it sounds like the pump is tripping the overheat relay. might be time for a new pump. depending on how far the 'tank above' is, you might not have enough pump to push water there.
    Jan 02, 2014 | Hayward 3/4hp Super Pump Inground Pool...
    Heat Pump, "open start circuit"
    Yes it is the start up on the compressor and then the other capacitor is the run cap after the start up. You need to replace the 45mfd cap
    Jun 03, 2013 | Heating & Cooling
    Will not start. motor hums
    Turn the motor on then immediately help it by spinning the chuck. If it spins up to speed and runs OK, you have a bad start capacitor on the motor. If it still does not work you may have something jambed in the pulley/belt system on top or a shorted out motor.
    Feb 21, 2013 | Craftsman 12" Drill Press (21914)
    I have a Rudd A/C-Heat Pump, model UBHA-14J11NFAAI. My Air-Handler fan is inop, with it switched to A/C or Fan only. My thermo seems to be ok. proper low voltage on all of the wiring down to unit. Had to...
    Hello,,there is a way to comfirm that but you will need a meter that reads microfarads, after discharging the capacitor with a insulated screwdriver you simply put you meter leads to each terminal on the capacitor with tje meter set to microfarads, if the capacitor is good it should read the same microfarad reading thats printed on the capacitor, if not replace the capacitor.
    Apr 26, 2011 | Ruud UBHC Air Conditioner
    How can I replace the water pump on a 2004 Grand Prix GTP superchargered?
    WELL YOU NEED TO DRAIN COOLANT SYSTEM.PLACE A LARGE DRAIN PAN UNDER THE RADIATOR TO CATCH COOLANT WHILE DRAINING RADIATOR.ONCE ALL COOLANT DRAINED OUT.REMOVE DRIVE BELT.REMOVE WATER PUMP PULLEY.REMOVE POWER STEERING PUMP AND MOVE IT ASIDE.THEN REMOVE WATER PUMP.MAKE WATER PUMP MOUNTING SURFACE CLEAN THEN INSTALL NEW WATER PUMP AND GASKET IN PLACE.IF WATER PUMP GASKET IS PAPER TYPE PUT GASKET SEALANT ON BOTH SIDES OF THE GASKET.IF YOU HAVE RUBBER GASKET DONT USE NO GASKET SEALANT.INSTALL NEW WATER PUMP TORQUE LONG BOLTS TO 25 FT LBS AND TORQUE SHORT BOLTS TO 16 FT LBS.TORQUE WATER PUMP PULLEY TO 115 INCH POUNDS.TORQUE POWER STEERING PUMP BOLTS TO 25 FT LBS.THEN INSTALL DRIVE BELT.FILL THE COOLANT SYSTEM.START THE VECHICLE AND CHECK FOR LEAKS.
    Mar 25, 2011 | Pontiac Grand Prix Cars & Trucks
    I've connected a powered sub (bazooka BTA10250D) to my factory system (09 altima coupe 2.5s). I want to be able to control bass on the component speakers and the subwoofer separately. There is no sub out...
    We used to use what we call bass blocker capacitors on the component speakers to block the bass coming from the head unit and to allow the bass to only come from the subs...there is several values of these capacitors that you can use(different values correlate to different frequencies). These type of capacitors are available at Radio Shack. You will need to request a NON-POLARIZED Electrolytic capacitor at a voltage rating of not less than 25 Volts...As for the value of the microfarad rating..you may need to experiment with different microfarad values to get the sound you desire...standard microfarad values are 1uF, 2.2uF, 3.3uF, 4.7uF, 10uF, 22 uF, 33uF, 47uF.
    You probably won't need to go any higher on the value than those listed....in my experience, I have found the 4.7uF and 10uF to be good for most speakers...to install these...you need to put one inline with the positive lead to each component speaker.
    Jan 14, 2011 | Bazooka BTA10250D Car Subwoofer
    I have a polaroid 37 inch flatscreen hd tv...the light for the power comes on but the screen will not come on...sometimes if you leave it on the screen comes on later..there is no sound until the screen...
    I did like everyone else has yesterday. I replaced (2) 1000 microfarad/ 10 volt capacitors on the power board with (2) $1.59 1000 microfarad 35v capacitors. I had to take the plastic cover off the back, then remove a metal cover to expose the board. You can follow the wires from the power cord. On my unit they are two small cylinders in the upper right corner of the board. The surfaces facing up were slightly bulging (indicates damage). I have a guy at work who messes with instruments all the time. It took him about 10 minutes. I got the capacitors at radio shack. The 35 volt capacitors are larger than the ones replaced, but fit in the available space, no problem.
    Jan 10, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
    I have a Polaris LR51044 pump that is not working. When I turn it on it "hums" but won't pump water. I live in Baton Rouge, La. and we have had freezing or below freezing weather for the last 2 days. The...
    Usually when a polaris booster pump hums it means 1 of 2 things; either the starting capacitor needs to be replaced (its located under the black hump on top of the motor) or the pump is bad. Most likely the starting capacitor needs to be replaces. This is where you should start since the capcitor is only $20-$30. Get a new capacitor from a local pool store, shut the power off to the motor, remove two screws on each side of black hump on top of motor, remove two wires from starting capacitor and install wires on new capacitor, replace cover and turn the pump on. If that doesn't work you will need to replace the motor.
    Jan 09, 2010 | Polaris Pb4 - 60 Booster Pump
    Heating & Cooling Logo
    144 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
