Question about Tablets & eReaders
Factory reset a maxwest 727 tab - Tablets & eReaders
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
Factory reset for galaxy tab
Method 1: From Startup (Tab 4)
  1. With the device off, press and hold the "Volume Up", "Home", and "Power" buttons.
  2. Release the buttons when you see the recovery screen and the Samsung logo.
  3. Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
  4. On the next screen, press "Volume Up" to continue.
Jul 15, 2016 | Samsung Galaxy Tab Tablet PC
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    Galaxy tab 4 encrypted how to do factory reset
    Gobto your settings then go to general then go to backup and reset open backup and reset and there you can factorybdata reset your device.
    Feb 19, 2016 | Samsung 10.1 Galaxy Tab 4 16GB White
    How can I reset my Galaxy tab 2 7 to its original settings?
    Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
    https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
    Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
    Jun 18, 2014
    How to Hard Reset the Galaxy Tab 3 - Android Forum ...
    May 7, 2014
    More results from www.androidpit.com
    Galaxy Note 5: How to Perform Soft & Hard Reset
    www.technipages.com/galaxy-note-5-how-to-reset
    Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
    How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
    ? 6:01
    https://www.youtube.com/watch?v=7sbgN0PxMzc
    May 2, 2013 - Uploaded by HARD RESET KING
    How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
    Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
    Reset to factory settings on Samsung galaxy 10.1
    Go to applications, settings, back up and reset. If you want to save your data check the "back up my data" box, then tap the "factory data reset" and tap the "reset tablet" tab. The tablet will then be reset to the original factory settings.
    Oct 02, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
    Maxwest tab-9155 won't load past android screen
    Hi, you can try resetting by following the below steps. It works for most tablets.
    1 turn off the tablet
    2 press and hold the power button and keep tapping the volume down button at the same time.
    3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
    please reply if it helped
    Mar 24, 2014 | Tablets & eReaders
    How can I get my Maxwest Tab-9100 to charge?
    This can happen when a faulty charger isn't providing enough voltage/current. Faulty chargers can provide enough power to trigger the 'Charging' indicator and maybe even to power the unit but not enough to energise the units charger circuit. Try another charger (same voltage) or charging it through the USB socket.
    Jun 05, 2013 | Other Maxwest Telecom TAB-9100 Wi-Fi...
    Maxwest tab 7150
    Maxwest Tab 7150 has password locked and needs to be unlocked please, thank you
    Apr 30, 2013 | Tablets & eReaders
    How to hard reset andriod maxwest tablet 70-F
    not sure if this is for your tablet but is all i could find on the internet.
    This hard reset can be done even if the device won't seem to power on.
    1. Make sure that it is OFF.
    2. Press the Volume Up and Power button simultaneously and hold them for few seconds.
    3. When you see the logo appear, release the Power button (but keep holding the Volume Up button).
    4. Next you'll see a menu where you can use the Volume Up & Volume Down buttons to navigate across. Check the option labeled as Wipe Data / Factory Reset using the Power button.
    Jun 18, 2012 | Tablets & eReaders
    Tablets & eReaders Logo
    60 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
