Question about The Office Equipment & Supplies
A sheet showing how to reassemble the hp4505 - The Office Equipment & Supplies
Recently replaced the LED strips on a LD 47LN5200 TV. Now I get a faint showwing of the LEDs on the picture Di I reassemble the difuser incorrectly Is the a correct sequence?
The film sheets and diffuser are orientation-critical and need to be reinstalled in the exact position and orientation that they were originally installed in. If you did not carefully lay them aside without disturbing their positions, then it will be almost impossible to get them back to normal.
Another possibility is the LED strips that you replaced are not staying adhered to the metal frame. Did you install new thermal adhesive tape to the strips you replaced? If the strips come loose and move closer to the diffuser, the LED outlines will show through.
There
Jul 18, 2016 | LG Televison & Video
Hi, The bulb has blown on my Russell Hobbs microwave, and the manual say to call out a technician! I don't have a top cover to open so can't replace it myself, and my manual doesn't show how to replac
The "top cover" is the wraparound sheet metal enclosure. It has to be removed to replace the lamp. The attaching screws often are special and require a special tool for removal. Se sure power is disconnected before beginning removal! Once inside, there are high voltage points to avoid while replacing the lamp. Reverse the procedure to reassemble the enclosure.
Sep 18, 2014 | Microwave Ovens
Repair ix4000 usb001
Even a tiny scrap of paper can cause the problem you describe. You will have to disconnect (not just turn off) power and use a bright light to examine as much of the paper path as you can see. It may be necessary to use compressed air to blow out areas that are not accessible. After reassembly and reconnection of power, you may find operation is back to normal.
Oct 14, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Samsung ML-2510 Printer. Picks up multiple sheets of paper most of the time.
I know this is an old post, but I thought I'd add this bit of info. I just fixed my ML-2010 by first replacing a torn pickup tire, but it still kept picking up multiple pages. I read a different post where the person traced it to a bad solenoid that was sticking in the open position as he described it. He replaced the solenoid, but on mine the solenoid was working, but I found it was sticking when closed. It is supposed to close and open once at the start of each page. Mine would close and stay closed sometimes until the start of the next page which would, of course, cause another pulse to energize the solenoid. I found it was due to a deteriorated thin half moon-shaped foam pad on the top of the solenoid's electromagnet that would cause the part that gets pulled in to stick to it for a couple of seconds before the spring would overcome the pad's stickiness and release it. I replaced the foam pad with a then piece of sticky-back felt that I cut to fit. When I reassembled it, it worked perfectly.
The way to get to the solenoid is to pull the covers, take the power supply boards off the back(as one unit, attached to a metal baseplate) and remove the panel underneath it, noting the screws and connections along the way. On the side where the solenoid is attached, I also saw a "split" gear that appeared to have a mark showing how they matched together, so be sure to realign the marks if they become separated before reassembly. Beyond that, it was a simple inexpensive repair. As these machines age, I would bet this is a major cause of this issue.
Feb 24, 2013 | Samsung ML-2510 Laser Printer
My samsung remote control is not working properly,some of few keys of remote control is not working after pressing hard it's some how work,please suggest the way out from this problem.
The Rubber contact sheet & PWB need cleaning. use isopropyl alcohol on a clean lint free cloth for best effect. wait until dry before reassembliing remote. If it doesn't improve things then it is too late - the rubber contact sheet is worn.
Aug 10, 2010 | Samsung Remote Control
Manual gardena t14e
I don't have parts sheet, and am looking for parts sheets and parts sellers to help folks at fixya.
Links to Gardena and possible Gardena manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Always take photos when disassembling products.
Jun 13, 2010 | GARDENA Water Timer
WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you. I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Nov 03, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water under vegetable bin
Oct 29, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
