Question about Air Tools & Compressors
Where to buy the bearing for nail drill pro power 35k
    Master:
  • 604 Answers
From the company
Posted on May 12, 2017
Where to buy the bearing for pro power 35k ?
one question please,buy it from the company
May 12, 2017 | Cars & Trucks
Why did it stop shooting brads. Shot 3 nails
It sounds like you have a bad seal or O-ring. without takeing it apart and looking at it myself i cant tell you witch one is bad.if take it apart look the orings and seals over reall well and se if you can find any distorted places on them and then you can find a breakdown of the nailer and buy the seals or O-rings on this site.http://www.ereplacementparts.com/
Apr 18, 2016 | Porter Cable-Cable FN250C 1-inch...
Nail stuck between driver and barrel
if you are a handy person you could drill the nail out providing you get the same size of drill and drill it out
with lots of coutions
Aug 02, 2017 | Porter Cable Drills
Need nails
You can use any hardened nails designed for .22 cal power shot drivers. The best place to look for them would be stores like The Home Depot, Lowe's, Menards or the like. You could use most nails from Hilti, Ram-Set or others that have the plastic or rubber 'fins' on them to help keep the nail centered in the barrell.
Feb 15, 2012 | Desa International 100PK RDN72 2 7/8" Pin
Not sure how to load nails
use left hand, slide spring retainer all the way to the back of nail tray, load a rack of nails into back of nail tray , tilt forward allow
nails to slide forwardthen slide spring retainer back slightly, release and let spring engage nails.
Feb 02, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
Nail is jammed in my Bostitch power finish nailer and partially sticking out. When pull on nail with pliers, it won't come out.
Remove driver guide nose peice, should be a couple of alan screws, remove nail, check driver to make sure it is not bent, re assemble. Make sure you are using the correct Nails!
Aug 27, 2010 | Stanley Bostitch N88rh Framing Nailer...
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
How to change bits on nail drill for natural and artificial nails(nail techs would know how to do this)
Most of the nail techs I've seen are using some variation of a Dremel or multi-tool. As I have never seen any nail tech take the machine directly to someones nails. I will assume there is and extension. You'll need two tools, a pin like a nail (woodworking nail not fingernail) and a wrench adjustable, vise grips whatever you have. There should be two holes just below the bit on the outer casing. Spin the center shaft until the hole in it lines up and stick the nail in it. This locks the center shaft so you can loosen the collet nut that holds the bit in place. Once it is loose you'll probably need to lightly tap the bit to get it to break free. Slap in a new bit tighten the nut, pull the pin out and your ready to go. Hope I didn't botch up what you meant by "nail tech".
Feb 12, 2010 | Drills
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
