Question about The Computers & Internet
If a cylindrical prism is 16m and 44m what is the surface area or if you cant find that then how do you solve this?
Hi! I think I can do your homework but I need a complete formulation of this problem. If you have it, please write it here.
Posted on May 12, 2017
Rectangular prism is made from centimeter cubes. What are the dimensions of the prism width x length x height? What is the surface area of the prism? What is the volume of the prism?
Dimension of the prism is the number of cubes in width x length x height.
Surface area is 2(w x l) + 2(l x h) + 2 (wxh)
Volume is the number of cubes.
Good luck,
Paul
Dec 07, 2016 | Office Equipment & Supplies
How do i do volume and surface area of triangular prism on ixl
Hello Jacqueline;
My name Peter. I am a engineering college graduate. Later I changed careers and now, I am a retired field service appliance technician. So, I work on the side and it you have any appliances that need repair call me @ 414306-1362.
The length on one side of the end triangle is "a"
The area of the end triangle is: (a x a) x 0.433 = Surface Area
The surface area of the prism face = a x length.
The volume is: The surface area of the end x the surface area of the face.
Mar 06, 2015 | ixl.com
Solid mensuration problem solving
First a square has equal sides, it means s= square root of 225 = 15.
Height of the base is equal to 15. Volume of the prism = Base area x Height = 225(15) = 3375 cu. cm x 1 liter / 1000 cu. cm = 3.375 liters
Ans = 3.375 liters
May 11, 2013 | Cars & Trucks
What is the surface area for 9in,4in,6in
The total area of the prism is made up of the areas of the two bases plus the lateral area.
Atotal =2 A_base +P_base*height. Here A_b is the area pf a base, and P_b is the perimeter of the base.
If you take the base to be a rectangle with length L=9in, and width W=4 in, then height= 6 in.
With this choice A_b=9*4=36 sq. in
P_b=2*(9+4)=26 in.
Now I leave the rest to you.
Understand this calculation and apply it to the other similar questions you posted.
Mar 05, 2013 | Computers & Internet
What is the surface area and volume for 14ft 12ft 3ft?
If that is a right rectangular prism
Volume =14*12*3 c.f.
For the area here is the formula.
Total area of right rectangular prism =2*A_b +P_b*h
A_b= area of base (take 14*12 feet squares)
P_b is perimeter of base (14+12)*2 =52 ft.
h is the height (3 ft)
Lateral area =P_b*h=52*3 feet square
Add all areas.
Mar 05, 2013 | SoftMath Algebrator - Algebra Homework...
Surface area of a rectangular prism whose length is 7 cm.,width is 4 cm., and thickness is 5 cm.?
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
  • surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
  • surface area = 2LW + 2(L+W)H
  • = 2 * 7 * 4 + 2*(7+4)*5
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Sep 05, 2011 | Encore Math Advantage Algebra II and...
What is the formula for getting the surface area of a trapezoidal prism?
Surface area of any prism is the sum of the areas of the sides
A trapezium is A = h(a + b)/2
h is the perpendicular height, a and b are the parallel sides
Aug 10, 2011 | Encore Math Advantage Algebra II and...
What is rectangular prism?
Hello
Rectangular Prism/Cuboid Definition:
A Rectangular Prism/Cuboid is a solid figure bounded by six rectangular faces, a rectangular box. All angles are right angles, and opposite faces of a cuboid are equal. It is also a right rectangular prism.
Rectangular Prism/Cuboid Formula:
Area of Base(A) = l * w
Perimeter of Base(P) = 2l + 2w
Surface Area of Prism = 2(lw) + (2l + 2w)h = 2A + Ph
Volume of Prism = lwh = Ah
Diagonal of Prism = Sqrt(l² + w² + h²)
where
l = length, w = width, h = height
Hope this helps, if so do rate the solution
Jan 15, 2011 | MathRescue Word Problems Of Algebra Lite
The difference between the inner and outer surfaces of a cylindrical pipe is 88cm sq..if the height of the cylindrical pipe is 14cm and the volume is 176cm cube. Find the inner and outer radius of the...
The surface area of the outer surface is the circumference of the outside of the pipe times its length. So, if OR is the radius of the outside of the pipe and SO is the outer surface area,
SO = 2 * pi * OR * 14
Similarly, the surface area of the outer surface is SI = 2 * pi * IR *14 (if SI is the inner surface area and IR is the radius of the inside of the pipe.
The question states that the difference between the outside surface area and the inside surface area is 88 sq. cm:
SO - SI = 88 ; substituting:
(2 * pi * OR * 14) - (2 * pi * IR * 14) = 88 ; factoring
(2 * pi * 14) (OR - IR) = 88 ;dividing both sides by 2*pi*14
(OR - IR) = 88/(2 * pi) = 88/(2 * 3.14159*14) = 1.00
So, the outside radius is 1 cm more than the inside radius.
It's not clear if the volume stated is the volume of the metal in the pipe or the volume of air inside the pipe, so I will solve it both ways:
If volume of 176cc is of the air inside, the formula for this volume is 14 * pi * IR *IR
176 = 14 * 3.14159 * IR * IR ; dividing both sides by 14 * 3.14159
176/(14 * 3.14159) = IR * IR ; doing the arithmetic
4 = IR * IR ; taking the square root of both sides
sqrt(4) = IR
IR = 2 cm
substituting back into the first equation, the OR is 1cm more than the IR, so
OR = 3 cm
If volume of 176cc is of the iron in the pipe, the formula for that volume is the difference between the volume of the outside of the pipe and the volume of the inside of the pipe, or
(14 * pi * OR * OR) - (14 * pi * IR * IR) = 176 ; factoring
(14 * pi) ((OR * OR) - (IR * IR)) = 176 ; dividing both sides by 14 * pi
((OR * OR) - (IR * IR)) = 176/(14 * 3.14159) = 4
but, since OR is 1 cm more than IR (from above), we can substitute OR = IR + 1
and OR * OR = (IR + 1) * (IR + 1) = (IR*IR) + 2*IR +1
So, ((OR * OR) - (IR * IR)) = 4 becomes
(IR*IR) + 2*IR +1 - (IR*IR) = 4 ; simplifying (IRsquared - IRsquared = 0)
2*IR + 1 = 4 ; subtract 1 from both sides
2*IR = 3 ; divide both sides by 2
IR = 3/2 ;
IR = 1.5cm
OR = 2.5cm
Jan 11, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
Computers & Internet Logo
314 people viewed this question
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
