Question about The Computers & Internet
I get a busy on the screen and tone is so light i can hardly hear it
What does reorder tone mean?
A busy tone (Busy Signal) and a reorder tone are two similar on-off repeating tones that differ in the spped that they beep on and off. Some lay terms for a reorder tone is a Fast Busy tone. Both types of tones use two different frequency tones simultaneously, 480 and 620 Hz, for the beep sound. Busy tones are a half second of tone and a half second of silence, repeated. Today's reorder tone is a quarter second of tone and a quarter second of silence repeated, twice as fast as a busy; a long time ago the cadence was a little different.
May 05, 2014 | Panasonic KXDT343 Phone
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Phone volume
In this case this machine doesnt have an exact way to increase the Dial Tone Volume...... We can try clearing NV RAM on the Printer........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now hear the Dial tone.......... It should work Fine......... Good Luck...........
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
I cannot dial out.
The dial may be defective and when you dial it is putting out erronous tones. When the Phone Company heres digits that do not correspond to a legal phone number it will give you a error tone or busy tone. It could be the phone got put on pulse and the line won't recognize the pulses
Dec 28, 2008 | Lands Phones
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Nokia 8800 blank screen
if u r able to hear the start up tone and key tones LCD may be the problem.In some cases flexi cable also may be the problem.
if the phone is not booting means(no start up tone and key tones) softwre issue. but s\w issue is very less
Nov 06, 2007 | Nokia 8800 Cellular Phone
Computers & Internet Logo
85 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
