Question about KitchenAid Dishwashers
How to replace springs and plastic busings on Superba Dishwasher
The model number is KDSM-21AC and we are going out of our minds ...thanks
3 Suggested Answers
SOURCE: Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Posted on Aug 24, 2009
Testimonial: "Hey, thanks for the advice. Worked like a charm. Hopefully Frigidaire has improved their design."
  • 110 Answers
SOURCE: Maytag Dishwasher Model No. MDB8601AWS Plastic
Source for 144 different parts for your dishwasher:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dishwasher-Parts/Model-MDB8601AWS10/3048/0130000?searchedModel=mdb8601aws&blt=
Posted on May 17, 2011
Superba KEBS277 broken door spring
go to appliancerepairpros.com or repair clinic .com..good luck...
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Our Kitchenaid KUDS01FLSS6 dishwasher door string broke, but unsure what I need to pull apart out to replace?
The "STRING" is referred to as a LINK. The link has a plastic connector glued to each end. It is common for the plastic to get brittle with age (even less than 5 years) or the nylon cord to wear down and break. That is why you see the frayed cord. You have to pull the dishwasher out to fix the problem. I had to order my link online because parts store in my city didn't have it in stock. Go to the Kitchenaid website to and key in your model number to get the parts schematic for your dishwasher. Under Customer Care, go to Locate Manuals and Guides, key in your model # and click Go. At the bottom of the web page you'll see Parts List. Click on the link and this pdf pops up: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194009.pdf.) From the schematic you can find on page 7 "Link, Door Balance" which is #24 part 8535568. The spring hooks on to the back of the dishwasher frame and runs parallel to the floor. The Link end with the round hole attaches to the spring and the other end slips/hooks over the bracket arm that is attached to the door. Good Luck
Feb 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water leaking
the plastic tray is either cracked or the busing is worn out. ice is building up in the catching tray and is one large ice cube?
Feb 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Spring coil came off inside grey plastic were tablet goes so tablet not disolving
go to appliancepros web site and put in model number. they show schematic of your unit and the various parts. then you know how it is supposed to look and if you need to replace.
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The Superba dishwasher is not longer heating the water hot enough that the dishes will dry themselves.
Your dishwasher has a heating element that heats the water. If you will callor email us with the model number, we'll send the right element out fo roy u to insyall. They are very easy to replace. Hope this helps!
Oct 06, 2009 | Dishwashers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher will not start up.
Hello, I solved this problem. I opened the front of the dishwasher (top) and replaced the thermal fuse and then looked at the mother board. The service company had placed two wires back onto the mother-board and were placed in the wrong slot. I moved the wires back to the right location and the dishwasher has since washed to loads without any problems. The service company has been fired.
Thank you for your help,
Jim
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba Dishwasher filter replacement problem
I dont think that it is made for you 2 move it.
If it isnt dirty then there isnt really no use. But if it is dirty write back and ill try to help you :)
Sep 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Dec 26, 2007 | Kenmore 24 in. 16492 / 16494 / 16499...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
