Question about Garden
When i start my zero turn it idols up and down, and definitely vibrates, when i engage the pto the mower just dies. note. the gas gap came off, some clippings got into the tank.
  • 604 Answers
Clean tank,fuel filter and carberator.
Posted on May 12, 2017
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ... > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
More results from
Sep 25, 2015 | Cub Cadet Garden
1 Answer turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
My toro 74411 seems like is notpumping enough gas cause when i engage the pto looses all power
one thing to try sstart up ngine le it warm up and get a screw diver and turn the mix screw on the carb 1/4 turn out and try that engage PTO if nothing turn another 1/4 if nothing turn engine of and turn mixure sew all the way in very easy dont force it just when it stops turn 1 and 1/4 turn to 1and 1/2 out now start it and try pto if its still slowing down turn another 1/4 turn out now if that didnt work just make sure you have a clean air filter and fuel filter and spark plug before you do any of the above then u will need carb rebuilt please use fresh gas otherwise you will very low power
Sep 10, 2012 | Toro Z Master Zero Turn Riding Lawn Mower...
When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Oct 13, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
