Question about Toshiba Televison & Video
How to reset a Toshiba 32c100u1 tv? - Toshiba Televison & Video
  • Toshiba Master
  • 3,093 Answers
Read the Owners Manual...
FREE at manualslib
Toshiba 32C100U1 Manuals
Carnac the Magnificent
Posted on May 12, 2017
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
Jan 12, 2013 | Toshiba Ct90325 Remote Control
Toshiba lcd 32c100u1 wont trun on
Hello
The power supply regulator board does not work in your TV. Just open it, and see whether any fuse has blown out. If there is any of it found, replace it with same type both in size and rating. Its ratins will be marked on it. If the replaced fuse also blow out as soon as you switch ON the set, never insert any more as it may damage more components with other boards. There is no repair to these type power baords. Replace it as card basis. You can buy it either from local electronic spare part market or from the authorised service center for Toshiba at your town. The picture of the bard is attached here for your recognization.
Oct 03, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
I hope that helps.
Tip
Toshiba 50HP95 Input Lock Reset
Toshiba 50HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Input Lock?
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Tip
I hope that helps.
Televison & Video Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
