Question about Samsung RS2630WW Side by Side Refrigerator
Rs2630ww/xaa freezer not freezing water
My freezer does not freeze water, seems cold enough to keep already frozen stuff froze, just wont freeze water (ice popsicles) side of fridge is too hot to touch on freezer side and center door strip.
  • 1 more comment
  • Bob Aug 14, 2009
    it was the condenser fan, works fine now
  • Bob Aug 15, 2009
    It was the condenser fan, replaced it and works fine now
  • Bob Aug 15, 2009
    It was the condenser fan, replaced it and all works fine now
Maytag317
  • 1136 Answers
SOURCE: the center of the fridge between the freezer and fridge is so hot you cant touch it whats wrong should I call a repair person ? thank you for any help
HI, this is a sign the fridge isn't cooling proper. Check and see if there is frost building up on the rear panel of the freezer. Check and see if the evaporator or the condensor fan motors are running. Check and see if the compressor is running.
Pleasae let me know if I can assist you fyrther.
Vic
Posted on May 21, 2009
  • 212 Answers
SOURCE: hot center strip
when the center mullion is hot then it means your units condensor fan motor is out. the fan is located by the compressor. this fan keeps the condensor coils cooled off. if the fan is not running then the unit vents through the cabinet.
Posted on Jun 24, 2009
thutch6911
  • 15 Answers
SOURCE: Stripe between fridge and freezer is extremely hot to touch
It is 100% the condensor fan motor on the back. Its not two hard to replace. Take the screws off the back panel and remove. Then locate fan. Disconnect the wires going to the motor and then unscrew the scews that mount the motor. Take the part to parts store of look it up online. Then simply remount motor and plug wires in.
Golden.
Posted on Jul 30, 2009
  • 736 Answers
SOURCE: my side by side kenmore refrigerator, freezer isnt freezing
in the back of the freezer there is an "evaporator coil" .. that has many fine fins and is used to cool the air .. you dont normally see it because there is a panel bolted over it ... if the door was left ajar for awhile then ice forms on the evaporator and stops air from flowing thru it ... the result is that it cant cool the freezer properly ... if this is the problem then you can fix it by taking everything out ( use an insulated tote to store things or use a neighbors frig overnight .... turn your refrigerator off or unplug it ... open both doors and let it thaw out for a day or overnight ... put down towells to collect the melting ice .. you can even blow warm air into the bottom of the freezer to make it thaw faster but be careful not to overheat plastic parts .. once the unit is completely free of internal ice then it should start to work again like new ..
Posted on Nov 12, 2009
Macmarkus
  • 2605 Answers
SOURCE: the fridge is hot the center deviding fridge and
Hi, welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal, yes...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.(where the doors come together when shut)
If all else appears fine (temp. Ok, fans running, no significant frost build up on freezer back wall) it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...In fact that is what I`d look for based on your post.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Posted on Jun 30, 2011
Lfx25971 will not dispense water
My water dispensor INSIDE the door froze up.... GE
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Jun 08, 2012 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Water dispenser frozen?
You have a resevoir inside the fridge compartment that needs to be defrosted. It is frozen.
It is usually located behind the crisper drawers.
It is a small plastic tank that is white about 6 inches or so in length and bolted on to the wall behind the crispers.
A hair dryer usually does the trick in about 10 mins.
Regards
Brian
Aug 06, 2008 | Jenn-Air JFC2089HE French Door...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Will not dispence water
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Won't make ice
some times low water pressure will freeze drain tube, a badwater valve wont give enough water quick enough and tricling water will freeze ion a a week or so its frozen!
Mar 17, 2008 | Refrigerators
Samsung RS2630WW Side by Side Refrigerator Logo
47 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
