Question about Cub Cadet Garden
Cub Cadet 1282. Model# 142-680-399. Will not start/turn over.Have clicking from Solenoid,changed out same thing.
Fyi previously same prob. but by flipping the pto switch back and forth would get it to start, nothing but clicking now.
  • Joshua Gann
    Joshua Gann May 12, 2017
    Might seem obvious, but have you checked/charged the battery? Btw, I've got a cub 682 in perfect running order that I'd love to trade for your single cylinder 1282! Farmergann at hotmail if you're interested :)
    New Friend:
    Problem Solver:
  • 5 Answers
Check Under Your Seat to see if your Safety Switch has A Broken Wire Or is Frayed or disconnected. They are designed Not to Start Unless Someone is sitting on it and stop if you get off. If that Wire has a Bare spot It Will Ground out and that's why The Solenoid will Engage But The Starter Will Not.
Posted on May 12, 2017
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
Why does My Cub Cadet 1282 stops running after 15 minutes and will start again after it cools--30 minutes
It could be a lean condition, meaning the fuel system is dirty. I think this model has points so they will need to replaced or try this. Clean then them with fine sand paper then set them to .020 that may fix your problem.
Jun 16, 2014 | Cub Cadet Garden
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
Apr 23, 2014 | Cub Cadet Garden
Cub cadet 2186 wont turn over or even "click"
be sure the blades are disengaged. the brake petal is depressed all the way and you are on the seat. might check the fuse. be sure battery has good connections and is fully charged. could also be the solenoid.
Feb 18, 2018 | Cub Cadet Garden
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
