Question about Garden
2615 pto on engine off how do i start it - Garden
2 Suggested Answers
  • 50514 Answers
SOURCE: 2615 ferguson stoped with pto on will not start cant turn pto off
try pushing in the clutch to energize the start circuit
Posted on May 12, 2017
May 12, 2017 | Garden
Engine stalled while pto engaged. Now pto will not disengage engine will not start. Act like it is locked up.
You will need to disengage the PTO before it will start as it is holding the engine back from starting. You should be able to disengage the PTO and roll the engine over and it should free itself up unless a bearing is hung up.
Apr 10, 2016 | Garden
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Pto will not dis-engage causing engine to not start
if it has belts it could be adjusted to tight
Aug 13, 2014 | Garden
How do you disengage the clutch after being left on when turning the engine off?
You can kill the engine with the PTO clutch on and then turn the PTO off before trying to restart because the PTO will auto disengage when the engine switch is turned off. The engine should not start if the PTO switch is on.
Jul 13, 2014 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
