Question about Simpson Washing Machines
Simpson encore 703 coming up with code PU?? - Simpson Washing Machines
tech240
  • 169 Answers
SOURCE: I have a Simpson encore
the manufacturer should be able to tell you what the error code means, look them up in your manual and call them or send them email. even though all codes may not be listed in the operating instructions they supply to consumers they will tell you when asked.
Posted on Apr 22, 2008
  • 1894 Answers
SOURCE: simpson encore 703
hmmm.. see. i told u right.. it is the coupler..
if the coupler has failed it keeps turning on only one side..
Posted on Jun 24, 2008
pride applia
  • 232 Answers
SOURCE: I have a Simpson encore 703. There is an
if power plug removed from wall and still fills replace valve
Posted on Dec 27, 2009
  • 69 Answers
SOURCE: machine will not stop filling with water
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure.   If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Posted on Mar 13, 2010
Testimonial: "Exactly pipointed the problem which is now fixed Thank you"
Daniel S
  • 4323 Answers
SOURCE: Simpson Encore 806 PU/PO display
Hi
The issue is with the control board that should be replaced as it is bad. You can unplug it and then blow air on the control before replacing if this wont solve the issue then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 08, 2011
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Simpson washing machine encore 756 displays error df and will not complete cycle
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Aug 03, 2008 | Washing Machines
Simpson encore 703
Jun 24, 2008 | Washing Machines
I have a Simpson encore 703 washing machine and it's coming up with the code P11. What does the code mean and what can I do about it?
Apr 22, 2008 | Washing Machines
Washing Machines Logo
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
