1 short beep and 1 long beep
Memory problem
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed
3 short beeps and 1 long beep
CPU configuration error or CPU type is not compatible
The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS :
BeepsDescription
1 short beep
Legacy floppy drive or CD/DVD drive not detected
2 short beeps
Floppy diskette or compact disc not detected
3 short beeps
Unable to start flashing (such as when missing a utility or BIOS image)
4 short beeps
Flashing failed (checksum error, corrupted image, etc.)
5 short beeps
BIOS recovery successful
If it has an internal centrifugal switch, usually under the cover at the rear of the pump, it might be stuck. Check it got movement. The weights on the switch move out away from the shaft when starting. If that is ok, possible capacitor.
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro)
TypePersonal computer
You may have been running it on the wrong voltage for 3 years especiallyif you feeding it 120 volts to a 220 setup. Assuming it is getting the right voltage and it clicks off and on you run winding is bad so the start winding cliicks on to bring it up to run speed opens the switch but the run winding isnt there so it repeats the process forever till it fails.
