Question about The Video Game Consoles & Games
How do I open the case to put in a disc? - The Video Game Consoles & Games
    Master:
  • The Master
  • 923 Answers
How do you open the case on what? Make, model, year, serial number? What is it that you are talking about?
Posted on May 12, 2017
I just received my Ematic EPD707BL. It opens with the word ematic. Nothing to click on for DVD or menu. When I put in a CD and DVD it says no disc
Check the connector from board to laser unit which is open for which it shows no disc. The lens is under the CD or DVD case.
Dec 05, 2017 | Tablets & eReaders
How do I get the CD drawer to open?
Normally, there is a small hole located below the disc drawer that you can put a straightened paper-clip in to open the drawer.
Feb 02, 2015 | Audio Players & Recorders
I hit the eject button and the drawer opened, but my disc was not there
It will take the removal of the CD drive and opening the case to dislodce the CD from the spindle.
Oct 20, 2014 | ASUS Computers & Internet
I put a disc in the drive and it stayed in the computer when the disc drive was opened
I am assuming that when the disc drive tray came out, the holder was empty, and you had placed the disc in the holder prior to this. Did you use the disc? Did it operate properly? Has your PC been tilted for any reason before trying to remove the disc? My feeling is the disc has to be SOMEWHERE! Take a flashlight and take a peak in the opened drive. Can you see the disc anywhere? Perhaps tweezers can be used with scotch tape wrapped around the points to keep it from scratching the disc. Grasp the edge of the disc and pull it out, if possible. If you can't find the disc, you should open the case and do a search. You might need to remove the drive itself, but hopefully you will get the disc back without needing to go to that step.
Jul 14, 2014 | HP 19-2014 All-in-One Desktop PC - ENERGY...
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
How to play movie dvd in playstation 2 ?
open dvd case.
take out disc.
place disc on ps2 disc tray.
put disc tray into console.
enjoy.
Jul 08, 2010 | Sony PlayStation 2 (PS2) Console
Cd tray will not open
This is not a solution but...I started to have this happen to me and I found a work around. reapeatedly try - many many times and when you DO get it open, put a disc in and see if it wil open after that. Make it a disc you can afford to never see again, just in case. On my 1620, as long as a disc in is in the machine, it will open. If you close the door when it is empty, it will be VERY difficult, but not impossible.
last resort, open the machine and slip a disc in, then try.if possible.Unplug it first, of course.
Ps
My machine worked great for 2 years before this started to happen.
Dec 15, 2009 | TruTech TT1620 DVD Recorder
Insignia Portable DVD Player does not play DVDs - says no Disc?
Unit needs to be returned for service under warranty. If not under warranty. You Must open the unit by removing all the screws on the bottom of the unit and use a small plastic pry bar to open the case around the space where the volume control is.slide the pry bar all around the case to open it.Becareful not to lose any of the switch cover that may fall off as you open the case. You must replace these covers exactly to operate the unit once reassembled. Check all rubber bumpers for hidden screws before trying to open the case. you must unlock the plastic locking mechanism all around the case. Then take apart the laser and motor assembly and disconnect all the wire straps and ribbon cables. Clean all these connectors with a contact cleaner by apply it to a cotton swab and cleaning. Try cleaning the laser with a cotton swab and Isopropyl alcohol. Put small amount of alcohol on swab and gently clean laser lens, Check transport for dirt and try cleaning the travel rails of the laser to remove dirt and grease and reapply a small amount of lithium grease to a swab . Lube the rails and ratching mechanism. Do all this with the utmost case, do not use to much grease or you will cause more problems..Use light gloves. do all the work with the cotton swabs. Check disc spindle and see if it is loose, if it is use a drop of super glue to to tighten the grip of the spindle to the motor shaft.Reassemble unit and put together in case put all screws back in unit and test unit on a level non vibrating surface. Use a clear disc from CD cases to check and see if laser is turning on and attempting to track normally. If this does not work attempt to polish laser head with soft foam material and non abrasive high gloss mirror or glass polish very carefully try to make the laser clear and shiney. Do not work to fast and do not push to hard on the laser or you will ruin the alignment.Slowly try to clear the lens of all discoloration.If all this fails try to buy a new laser mechanism from e-bay and replace your old one. Hope this helps you with your problem.
Nov 28, 2008 | Insignia IS-PDVD10 Portable DVD Player
Wii disc
ok there is a safe way which requires opening top case try not to turn wii to much while taken off the top case this will keep your cd's from getting scratched
the cd's have lodged ontop the back plate
the other way
turn side ways you should be able to shake machine youll here the cd's slide onto each other lay flat and both cd's should slide out on tray
this will definatley scratch your cd's but it does work and its a form of the shuffle
May 28, 2008 | Nintendo Wii Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
