Question about Ducane Grilling
What size capacitor does a ducane AC10B16 use
2 Suggested Answers
claudeinmo
  • 9098 Answers
SOURCE: What is the capacitor size for Ducane air conditioner model number AC12B36
It is stamped on the existing capacitor.
Posted on Jul 10, 2015
Can I get the capacitor model number for a Ducane ac. Picture attached.
http://www.americanhvacparts.com/p-21830-50-75-mfd-370-volt-dual-round-run-capacitor.aspx
Jul 08, 2016 | Ducane Grilling
Hello what is the capacitor model needed for a Ducane AC 10B18? Mine is rusted out.
Ducane furnace
check wires connecting to motor capacitor
Oct 13, 2013 | Heating & Cooling
Lost my ducane 3040042 instruction manual. can I download one. t
Yes you sure can. Go to the following link and find your grill. If yours is not listed there, cal Ducane's Customer Support number.
moz-screenshot.pnghttp://www.ducane.com/manuals/
Happy Grilling!!!
Apr 17, 2011 | Ducane 30400042 (LP)
Ducane heater burners ignite but the fan won't turn , has a hum. fan will turn by hand.
There are 3 possible causes for this problem. Either you have low voltage to the motor, you should have 120 volts, or the run capacitor for this motor is defective, or the motor itself is defective (motor windings).If the motor is bad and you replace it make sure you replace the capacitor as well.
Nov 12, 2009 | Heating & Cooling
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
Cannot light new burners
I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
How to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
May 01, 2008 | Ducane 30400042 (LP)
Grilling Logo
66 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
