Question about Craftsman Garden
Installed new clutch and shoes on craftsman 4cycle mini tiller.still doesn't work.Took it apart again the drum is loose I know about the torx-headed screw in the stem of the drum and reverse thread
I used the rope in the cylinder to loosen and tighten.What else can I do? The model# 316.299372 Craftsman 4-cycle mini-tller
    Master:
  • 604 Answers
Where can I get an owner's manual?
-Down load from the manufacture that make it.
Good Luck
Mai Lor
May 18, 2015 | Mtd Craftsman 4Cycle Mini Tiller
Can I replace just the primer bulb
yes useing a thin small screwdriver slide it down the side and work the spring slowly out revers this to put a new one in
Feb 14, 2013 | Mtd Craftsman 4Cycle Mini Tiller
I have a 26cc 4cycle mini tiller that has a broken re-coil starter rope on it. I've got it all tore apart EXCEPT for the flywheel (I guess that's what it is) or maybe it's the cone clutch that...
you are on the right track.. you will need a torx bit for the screw in the middle of the clutch cone, your local auto parts store should have them, I think it's #15 but not sure, pull your spark plug out and put cord into cylinder to stop crankshaft from rotating while you remove this screw, next you need to remove clutch by using a screwdriver or brass rod and giving it a hard smack with a hammer, should be an arrow showing which way off, once that is off then you can finish dismantling the case and fix your spring and rope
Jul 29, 2011 | Garden
Hard to start and oil soaked air filter, smokes and loses power
It sounds like it got tilted on its side. The air filter needs to be cleaned or replaced and the carburetor needs to be removed and cleaned.
When the tiller gets tipped over toward the air filter, oil will run out into the filter and the carburetor.
If the filter is foam you can clean it with gasoline, if its paper just buy a new one.
The carburetor is between the air filter box and the engine, it should come off with a few bolts, just remember where the springs hook up.
Open it up, take it apart and spray everything with carburetor cleaner from your local auto parts store. When you put it all together it will run like new!
Jun 08, 2011 | Mtd Craftsman 4Cycle Mini Tiller
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
Hello. I saw an ad here about How do you take the drum clutch off but I did not see an answer. So I am going to ask again.Could some one tell me who to take off the drum clutch. Of a craftman 32cc gas line...
Without knowing exactly what model you have. Some of the clutch drums are held on by a single screw (usually torx head) that is accessible through the center of the shaft of the drum. Hope this helps.
Feb 18, 2011 | Craftsman Garden
Craftsman mini tiller
Craftsman mini tiller. Are you selling this unit, giving it away or what. Your information is somewhat meager to say the least.
May 28, 2010 | Craftsman Gas Mini - Tiller/Edger
The motor runs but the trimmer head turns slowly or not at all.
The problem may not be in the clutch assembly, if you took the engine apart you would have noticed a lot of debris if a lining had been stripped off. I would start with the lower flexible shaft assembly. This is probably where you will find something that is noticeably worn.
Here is a link to a Owner Manual / Parts listing. So you can see what the pieces should look like.
http://dl.owneriq.net/3/3e126dac-25ea-6974-e50f-90c9e8b1387a.pdf
If the link doesn't work here's where you can download it for free.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss_4.html
Feb 11, 2010 | Troy Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
