Question about DeLonghi Heating & Cooling
Delonghi customer service could not tell me how to open..or was in any way helpful.. Said no service place anywhere near Memphis..they said this units reservoir I would not be able to get to..
The portable air conditioner is 3yrs leaking considerably out the bottom, but is still operating fine. Level and well vented,,what is the cause?
  • 63 Answers
SOURCE: Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
  • 69 Answers
SOURCE: Describe your Kenmore Air Conditioner Proble. My
the vent is a fresh air intake, when it is pulled open you are mixing outdoor air in the unit. when it is hot and humid outside you will make the unit struggle to cool. Leave the vent closed.
Posted on Aug 23, 2009
  • 767 Answers
SOURCE: Air conditioner unit is leaking water from the bottom
Hello my name is Heath it will be my pleasure to assist you. First use a level and make sure the unit is level front and back and sisde to side. Next be sure the drain hose is not plugged or stopped by any debris.
Posted on Jun 03, 2010
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
Posted on Jul 06, 2010
  • 3 Answers
SOURCE: DeLonghi A120 12,000 btu ar conditioner Leaks
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Posted on Jul 26, 2010
DeLonghi ceramic portable heater dch7093er model. PF error code. How do I clear
If The PF shows and emits a beep then the temperature sensor is malfunctioning. If the problem continues then call customer service at 1-800-332-3848. When you unplug unit the code should clear if not then there is a problem with unit. DO NOT try to keep running unit this could cause a fire.
Mar 02, 2015 | DeLonghi Heating & Cooling
Delonghi repairs sydney
Hello -
This is the link to the Delonghi Australia web page you can use to find a nearby repair center :
Best wishes.
Feb 13, 2018 | Bodum Coffee Makers & Espresso Machines
You should be able to find help at the DeLonghi customer service site.
Oct 27, 2011 | DeLonghi MW 605 Convection/Microwave Oven
The unit is several years old and throws out warm air. I shut it off for a few days and when I started it back up the air continues to blow warm. I also cleaned the filter and drained it. Where can I get...
The best way to find a repair center area you is to call Delonghi Customer Service 800-322-3848. Ironically, their USA operation is also located in NJ.
Hope this helped you and thanks for choosing FixYa.
Aug 22, 2011 | DeLonghi PACA110 Portable Air Conditioner
I need the Manual for a Delonghi Microwavemodel EM821AAM
Jan 31, 2010 | DeLonghi Microwave Ovens
I need replacement parts - lid
Go to you can order replacement parts. If your model is older go to customer service and they will tell you if you can still buy part.
May 16, 2009 | DeLonghi DCU72 Coffee Maker
Delonghi Dehumidifier DE500P - Code E3
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
Oct 22, 2008 | DeLonghi DE500 Dehumidifier
Memphis codes
Most scanners require you to program frequencies manually before you can scann them. Your instruction manual will tell you how to do this.
If you need Memphis frequencies, go to these links:
Memphis, TN
Memphis, AR
Rollin Cbs
May 02, 2008 | Uniden BC244CLT Base Scanner
DeLonghi EC701 Pump out
I had the same issue. Scale build up in the port that routes water to the boiler outlet for the coffee filter basket. Frother tube was fine.
I used CLR to open it back up. Used 1 part to 4 of water and ran a whole reserviour through the unit. At first, it only dripped and then finally it blew open when the CLR dissolved the scale.
Make sure to run lots of clean water through the unit after so that you don't end up drinking acid with your next cup. I ran about a gallon through to rinse it out.
Jan 08, 2008 | DeLonghi EC701 Espresso Machine
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
