Question about Maytag Washing Machines
Maytag centennial MVWC425BW0 will not agitate
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do I remove the agitator on a Maytag
Here is a nice video:
My Tip How it works: Direct drive washer
Posted on Jul 23, 2010
e-Guru
  • 3917 Answers
SOURCE: 18 months old, Maytag Centennial
Hi
May be a plugged Pressure Hose connected to the Water Level Switch in the Control Panel,
other end connects to Tub. Try blowing through the Pressure Tube .
This problem is going to be in the water level control or the tube that connects to the control may be partially clogged. if it is partially clogged the tube can retain pressure essentially fooling the water level control into thinking the tub is full. The best thing to do is to take the washer apart and check the tube to see if it is clogged and if not replace the water level control.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 03, 2011
SOURCE: Maytag Centennial washer agitates when
Don't know what it is , but the 3 guys above me are wrong
Posted on Oct 16, 2012
richroth
  • 9472 Answers
SOURCE: my maytag centennial washer has been making a weird noise during agitation and today it stopped agitating at all. Need assistance please.
What is the complete model number of the unit?
Posted on Dec 09, 2012
Model # MVWC425BW0 Maytag Centennial
May have to reset your washer to default mode or unplug for a few minutes then plug back in. It should work after that.
Mar 11, 2016 | Maytag Washing Machines
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial washer will not agitate
If it is belt driven the belt might be broken. It is underneath the washer
Apr 03, 2014 | Maytag Centennial Top Load Washer
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
