Question about Sunbeam Coffee Makers & Espresso Machines
Sunbeam cafe series - no steam - pressure gauge not working
SOURCE: i have been given a sunbeam cafee series coffee
Was given a book by a freind, but thanks
Posted on Sep 20, 2009
SOURCE: I would like to get an extra extension nozzle for
Sunbeam have very kindly agreed to send me this extension nozzle.
Posted on Oct 07, 2009
SOURCE: KITCHENAID ESPRESSO 5KES100 steam pressure gauge not working
I had a similar problem. I took the guages out and found the hands were loose on the dials. I fixed them on at gthe low point when the machine was cold and they worked well after that point.
Posted on Feb 07, 2010
espressonist
  • 1711 Answers
SOURCE: I need the operating manual
Here is the manual
Posted on Aug 06, 2011
paddyz65
SOURCE: My Sunbeam coffee machine model
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Posted on Jun 06, 2012
Why no steam.Sunbeam 6910 cafe series. Turned on steam wand this morning and all I heard was a sigh, a feint try to deliver steam but not successful. Very little pump noise / action almost non-existent....
This could be 1 of many issues, usually the Steam pump (black or blue) is corroded and no longer vibrating correctly, the pump could be blocked, the pipe work after pump but before boiler could be blocked, the steam boiler could be blocked, the pipe work after steam boiler but before the steam tap could be blocked, the steam tap could be blocked, and also the milk nozzle could be blocked, if you feel competent to take it apart, it is easy to fix but if not take the machine to local service agent.
Feb 20, 2015 | Sunbeam Cafe EM6910
Sunbeam troubleshooting
Sounds like the flow to the steam pump and or steam block is clogged.
Aug 25, 2014 | Sunbeam Cafe EM6910
Why don't the three lights come on after a warm up period?
Is it actually getting warm/hot? The thermal fuses on the Cafe Series often blow after a few years, so the machine doesn't go into ready state.
It's a replaceable part bolted to the steam thermoblock. Costs about $9.
Apr 25, 2014 | Sunbeam Cafe EM6910
The steam wand on my sunbeam cafe series is not working
Is it still making the correct pumping noise? If so, unscrew the knob from the end and unblock the steam head and wand with a bit of wire.
If it doesn't sound like it is pumping, either the microswitch in the left-hand dial is faulty or the steam pump is dead. To test the microswitch, pull the steam dial off and try to get the switch to make a connection (it's hidden at about 2 o'clock in the housing). Failing that you're up for a steam pump... about $80.
Apr 21, 2014 | Sunbeam Cafe EM6910
Wet steam, poor pressure
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Apr 12, 2014 | Sunbeam Cafe EM6910
Sunbeam em6910 leaking steam
Pull the steam dial off (there's nothing holding it on apart from friction). Unscrew the small screw in the middle of the plastic holder, and adjust the position of the copper steam tap using pliers to turn the steam fully off. When reattach the plastic cover and then the dial. The dial will now have the correct range to turn the steam off.
Apr 02, 2014 | Sunbeam Cafe EM6910
EM6910 - I am having problems with the pressure from the steam. Any suggestions on how to fix it.
Have a look at your manual and see if you can adjust the steam pressure. I saw it recently as I'm having trouble with the red light flashing despite the water reservoir being full. Hope this helps.
Oct 05, 2012 | Sunbeam Cafe EM6910
Steam wand doesn't work on sunbeam cafe series coffee machine
Sep 11, 2012 | Sunbeam Cafe EM6910
How to clean and descale sunbeam cafe thermoblock
red light flashing next to water meter of sunbeam coffee
series and making a noise
Mar 20, 2012 | Sunbeam Cafe EM6910
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
Feb 01, 2011 | Sunbeam Microwave Ovens
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
