Question about Frigidaire Dishwashers
I have a Frigidaire Dishwasher Gallery Model #FGHD2465NF1A. Getting an ER code. Changed control board. Initially got PF and then back to the ER code. Please advise.
  • 93 Answers
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Posted on Jul 24, 2008
ngfam1
  • 639 Answers
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
shastalaker7
  • 1515 Answers
SOURCE: just installed the dishwasher and
Hi, I am doing some Research at this moment. Will get back to you,
Shastalaker7
Posted on Nov 06, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
I have a PLD4555RFC dish washer and I'm getting the err display it will runn thru a whole cycle and right before the end it gives the err message is this solvedby doing the same sequence
Hello Ken R, thanks for the post!
I understand that your Frigidaire dishwasher, PLD455RFC, is going through the whole cycle and then will provide you an ER code. The code ER on a Frigidaire dishwasher stands for a membrane switch failure. Generally that means that the main control board has detected a stuck key or a key pressed in for more than a minute. I see you have already attempted to reset your appliance and you are still receiving an ER code. Some possibilities that could be causing this problem are a wiring issue or main control board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. I hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire PLD4555RFC Dishwasher
My Frigidaire Gallery dishwasher will run initially when i oporate it on a normal cycle. The time will start to lower then, it will go back to 90 minutes and then shut off and then a PF code will appear. ...
Hi Gabriel, thank you for allowing me to assist you. PF is commonly referred to a power failure and you should be able to start a cycle. Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it. I hope this information proves to be helpful in a small way.
Aug 05, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Need manual
Good Morning Steve - I am happy to assist you, however according to my database I'm not showing that Frigidaire has an error code FR for a dishwasher or for any product for that matter. Could the error code possibly be an ER, PF, FL or RF?
· Typically error code ER indicates that the main control board has detected a stuck key or a key pressed for more than one minute.
· Generally error code PF means that the dishwasher has experienced a power failure and you should be able to resume the cycle.
· Error code FL is advising you that the water valve is in the open position.
· RF indicates that the rinse aid reed switch in dispenser is open and needs to refill the rinse aid.
Let's try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the dishwasher. If issue persists, then I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
I hope these troubleshooting tips help you in some small way.
Jun 25, 2013 | Frigidaire Professional Series 24 in....
Frigidaire gallery FGHD2433kw1 error washing clean drying ER s ...
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Aug 23, 2011 | Frigidaire FGHD2433K 24 in Builtin...
I have pf code on the display already changed the control board same code as befor
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Feb 05, 2011 | Frigidaire Professional Series 24 in....
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
I have this code error on my dishwasher frigidaire gallery Sensing Sanitazed......Er......Low Clean.......................*
Jul 24, 2008 | Frigidaire Dishwashers
Dishwashers Logo
158 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
