Question about The Office Equipment & Supplies
I want you to help me identify the problem of My MP3054. Its a new machine and recently I encountered some faded lines. What is this problem all about?
Can anyone explain to me when copied there is a faded area on the copied paper? What is the problem here? is there anything I can fixed? and How?
SOURCE: PIXMA MP780 Canon Copier skipping lines
Try cleaning printhead (google it you find it) make sure you attempt cleaning with Windex ammonia D (overnight solution)
If not you may have to replace Printhead (Plastic Box, cartridges snap into) sometimes the resistor will burn out.
1-800-828-4040 (Direct from Canon $31 + shipping)
If that doesn''t work contact www.usa.canon.com and find authorized printer repair. location. I am having same problem!!!
Posted on Mar 31, 2008
SOURCE: My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Posted on May 01, 2009
playedaround
SOURCE: PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Posted on May 27, 2009
rioglen
  • 95 Answers
SOURCE: black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Posted on Sep 23, 2009
qwertyisone
  • 6 Answers
SOURCE: Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Aug 19, 2010
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computers & Internet
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
Eadch line of text is slightly faded at the bottom from laserjet 1100
It is possible that the transfer roller needs replacing as this causes it. Have you recently wiped clean the black roller that sits under the toner cartridge if you have you may have damaged it.
Best thing is to replace the transfer roller very easy to do and not expensive.
Hope this works for you and please rate me
Thanks J
Oct 11, 2007 | HP LaserJet 1100 Printer
Zanussi washing machine.
i am a recently retired engineer of 20 years, and i have found that generally the numbers and letters are the same throughout, so the number 2 on one machine is the same as the number 2 on another make, so this rule applies for letters also, just remember what you used on your old machine and you cant go far wrong hope this helps
Sep 19, 2007 | Washing Machines
Picture Fades to Black
Sounds to me like a bad solder connection. I would suspect the crt filiments first, since you said it fades out. Could be bad solder connections any number of places.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
26 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
