Televison & Video Logo
Les Grant Posted on May 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why am I getting double colored lines on either side of my rear projection tv?
Lawrence Oravetz
Level 3:
  • Televison & ... Master 10,558 Answers
  • Posted on May 12, 2017
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2699996
Points
29284
The coolant for the face of the tubes may need to be changed if your model allows that. It's harder to get service parts and supplies for 3 tube projectors. The tubes themselves have a service life of about 3000 hours of operation. If the tubes are available for your TV, they won't be cheap and it takes a technician to properly replace those tubes. You may want to upgrade to a flat screen TV simply because it will be much cheaper than repairing your projection TV
johnny rebel
Level 3:
Master:
  • Master 604 Answers
johnny rebel
Master
Level 3:
Master:
Answers
604
Questions
0
Helped
136539
Points
2001
Its old and needs to be replaced with a flat screen tv
3helpful
2answers
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Hitachi 57'' rear projection tv has double images on both sides.
tv looks in the center and have double and multiples colors . majic focous do not fix t
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Picture double an inch from the left side
Your TV most likely has a convergence problem.
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
www.TvRepairKits.com
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
