Question about HP Garden
What is the composition of the steering wheel fitted to a Cox Lawn Boss 18.5 hp ride-on mower?
  • 142 Answers
SOURCE: front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
Posted on Sep 20, 2008
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 6468 Answers
SOURCE: Troy Bilt riding Lawn Mower will not steer
at the bottom of the shaft there is a plastic union that keeps the gear against the other gear they crack and then the steering jumps on the gear
Posted on Jun 04, 2012
  • 12 Answers
SOURCE: adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Posted on Jul 02, 2012
  • 6468 Answers
SOURCE: can't remove the rear wheel from a cox lawn boss
it is common for the rear wheels to get stuck to the axle i just change the tires or add a tube while its on the axle you will damage more trying to get them off
Posted on Oct 02, 2012
Is there a larger steering wheel that fits Husky YTA19k42 mower? Standard is approx 12" diameter.
Have you tried a steering wheel handle? Small knob that fits to a steering wheel which saves having to grip the wheel. People with dexterity difficulties use them on cars here in the UK, here's a video of one from the US
Apr 26, 2015 | Husqvarna YTA19K42 42 inch 19 HP Kohler...
Why would my cox lawn boss stop driving forward and back when I engage the mower deck
Sounds like a drive lockout switch. Check under seat or dash. EBrake? Good Luck
Oct 18, 2014 | Garden
Cox mowers manuals
Go to Cox website, www.coxmowers.com.au and download the appropriate manual. They're free !!
Aug 08, 2014 | Garden
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Can't remove the rear wheel from a cox lawn boss
Sep 30, 2012 | Garden
I have a 2 year old Cub Cadet and I find it very hard to steer the wheels during mowing.
First grease the the axles and all steering components associated with steering, there should be grease fittings where you can pump grease into, then make sure your tires are all filled to proper psi. Good Luck...
May 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removal of rear wheel on cox stockman ride on mower
These wheels are usually just held on with a Key way, ALOT OF TIME they offer resistance because they are rusted insode the rim and are needing a mallet to hit them from the inside pretty hard.
Turn it as you can usually a lever on the back side of the mower can be pulled out without the brake on to slip the transmission into nuetral. Turn the tire. I have used a small peice of 2x4 as well because a hammer dont fit well. Good luck I will watch this post and search my Diagrams to see if i have this rider tmrw at work.!
Feb 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
