Question about Sansui Audio Players & Recorders
Sansui d-x111hx Can anyone tell me how to set the bias control knob on this cassette deck? I can't find a user manual for it to save my life. The rest of the controls I understand. Thanks
3 Suggested Answers
  • 54 Answers
SOURCE: what is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Posted on Mar 29, 2012
SOURCE: Looking for Technics RS-B905 cassette deck owner's
http://www.hifiengine.com/news/technics-rs-b905.shtml
Posted on Nov 13, 2012
How do I set up my jvc_td309 double cassette deck for recording on cassette tapes? Also what settings?
Adjust recording bias, if one, for the kind of tape you are using and you are good to go. For best performance use the brand of tape that was used to set up the machine when made.
If you have a fine tuning control for the bias, use it per instructions for best frequency response and s/n ratio.
Nov 16, 2015 | Audio Players & Recorders
Difference between a Yamaha KX 580 and a KX 580 SE cassette deck
Managed to find this blurb...
"The KX - 580SE is a refined model of the popular KX - 580, three time winner of ''What Hi Fi? Best Cassette Deck Award''. The KX - 580SE is a special edition which is UK specified. This cassette deck features CD to tape synchronized record start, timer record / play, new audiophile components in both the dolby and audio output stages, two - motor stable transport, Dolby HX pro dynamic bias servo, auto tape tuning and improved power supply."
Feb 11, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
What is the bias control's function?
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
16 year old Blaupunkt Toronto SQR 48 on/off/volume control knob ?
blaupunkt doesn't supply parts after ten years on their decks. you can try salvage yards.
Mar 03, 2010 | Car Audio & Video
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
May 02, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
Recording problem onkya model ta2090
check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Oct 31, 2007 | Onkyo TA RW544 Single Dual Cassette Deck
49 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
