Question about Yamaha Boating
Have a 2 stroke 225 Yamaha outboard. Alarm for what I can tell for heat, an oil went off today. Runs fine at lower rpm, but goes off when it goes up beyond 21 rpm.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
How long has it been since you changed your water pump? The pressure relief valve can also cause over heat issues if it is stuck.
Posted on Aug 20, 2017
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
  • 23 Answers
SOURCE: Yamaha 30 HP 3 cylinder 2 stroke
Did you change plugs? If you did chek the plug to see if piston has hit the end of plug. Do a compresion check Jim OMC retired Mech
Posted on Jul 07, 2009
  • 53 Answers
SOURCE: yamaha outboard 150 4 stroke bad vibration at 700
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Posted on Nov 03, 2009
SOURCE: 90hp 4 stroke suzuki outboard how do i reset the oil alarm?
Posted on Apr 15, 2010
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
year make HP manual
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
Help with my 1994 Yamaha 150Hp
Outboards have thermostats...the tattle tale can be pouring water and the engine still overheat if the thermostat is stuck or airlocked.
May 07, 2014 | Boating
I have a 98 yamaha 150 2 stroke outboard engine, when cruising about 23 mph she runs fine, but when i run her faster a alarm under the dash goes off in which i will slow it down to idle and the alarm will...
Although water is seen thru the tell tail hole, your engine is overheating. When were the thermostats replaced last? Water pump impeller may also be fatigued, and not pumping enough at high RPM's.
May 11, 2010 | Boating
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
Hello, I have a Yamaha 9.9 outboard engine, it stars without any problem. When I ref it up just above idle it dies after a few seconds. There is fuel, fuel filter in the line is no blocked.
Yamaha outboard that runs fine until heat light come on and it idles down. When light goes offf it runs fine. What is causing heat problem
Jun 06, 2009 | Yamaha Water Sport
Boating Logo
163 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
