Question about The Computers & Internet
Is there a way to brighten the led display on my coffeemachine
The menu doesn't display a brighten button -- how do I brighten the display?
go to settings and find picture controls then find brightness
May 24, 2015 | Dell E156FP 15" LCD Monitor
How do i brighten the display
There is no way to brighten the display. If it's dimmer than it was when new, the control board will need to be replaced.
Feb 19, 2015 | Electric GE PVM9195DFWW Profile 1.9 Cu....
Ordered one cuisinart coffeemachine DCC1200 from the US put in elecricity with transformer unit (european electricity) and never worked. Did I burn the heating element?Can it be bought seperatly, how do I...
depends on the wattage of your converter..if its a coffee machine, you need a larger converter that will handle the wattage needs of the coffee machine..say if its a 1200 watt unit, you easily need a 1500 watt converter..I lived in germany 3 years..our stereos were 110.. we used huge converters some in exess of 50,000 watts(huge sound system)its a math thing..usually you will need 10% more converter for the wattage size of your appliance..
Jan 08, 2014 | Cuisinart DCC-1200 Coffee Maker
G shock model 5255 display is dark. Is there any way I can brightened the digital display ?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 20, 2013 | Computers & Internet
My screen brightness its lees
Then brighten it. You brighten it by Holding Down either FN, CTRL or DEL key + Hit the corresponding key for brightening the display.
For example on my computer I press and hold the FN Function key while I hit the UP Arrow key to brighten the screen.
The brighten/darken keys normally have the icon of a circle with sprockets around it like the sun or it looks like a washer that goes between a screw.
Mar 23, 2012 | Toshiba Qosmio G45-AV690 17" Laptop PC...
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
On my Murano when headlights are on the AV display unit goes dark
the av may be bad, if the other lights brighten then the av is bad, there are led bulbs but they are part of the circut board.hope this helps.
Oct 20, 2009 | 2009 Nissan Murano
Temperature LED
no way to brighten with out replacing entire clock/control unit.
Feb 23, 2008 | Kenmore 72012 / 72014 Kitchen Range
I can't get the led read out to brighten?
Does the dimmer switch in your truck make nthe light in the radio go up and down? if not the instalation was not done properly and someone left off the dimmer wire. If that does work and the brightness does go up and down, you may have an LED or Two out on the radio. Good Luck
Mar 23, 2007 | Sony CDX-5090 CD Changer
Computers & Internet Logo
71 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
