Question about Ricoh Office Equipment & Supplies
How can I fixed my Ricoh MP3054?
When I photocopy the original paper outcome on the copied paper has a faded area? what is this problem mean.
ctf1800
  • 4402 Answers
SOURCE: ricoh photocopier 1075 code sc541
500's usually means overheating problem
contact service support from your local authorized dealer
Posted on Jan 10, 2008
drichards
  • 87 Answers
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Posted on Mar 19, 2008
SOURCE: I have a Canon IR6570 photocopier . Image problems.
E0225-0001 salve this probluem
Posted on Dec 28, 2009
santosj27
  • 263 Answers
SOURCE: I have a Ricoh Aficio
This jam problems are always very difficult to solve without seeing the machine!
Because i need to see the jam location or take a report to see where the paper jams.
you say that it is on the Point C, but that just helps a little.
I can tell you that you have a problem in the duplex door (but you already know that). It could be several things like; transport rollers, gates, solenoids... well, the best help i can give you is to advise you to call your technical support.
See you!
Posted on Apr 30, 2011
Testimonial: "thanks for the help you could give! ill have to have a look to see what i can do"
  • 903 Answers
SOURCE: functional problem sc 390 on ricoh photocopier,
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Posted on Aug 24, 2011
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
We are getting the following error message when we turn on power. "Functional problem within the Copier. Please call service and report the service code SC552". Ricoh Copier Model MP5001
That is a fuser under heat condition.
Try this. May take a couple of times to clear.
Press the in this order. Clear all ( yellow button) then press 107, then press and hold the red stop button until the screen changes to show a screen that says. Copy SP ,,, Print SP etc.
Press Copy SP, when the screen changes, shut the main power off then back on.
If that doesnt work then repeat the clear all 107 stop and enter Copy SP again, Then scroll down to the 5 tab. press it, scroll to 810 and preform that reset.
If that doesnt fix the problem, then most likely the thermistors and over heat thermostats will need to be replaced.
Jan 29, 2011 | Ricoh Office Equipment & Supplies
Making a clean copy of an old fainted typed document
I installed paint.net and adjusted the contrast level of the document. Excellent.
Jan 02, 2010 | Office Equipment & Supplies
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
