Using Canon iP4600, I'm trying to print a black-and-white photo with a black background and a half-tone image in the front, but I keep getting purplish and black stripes instead of an all black background. Eventually the black got blacker, although the half-tone had a greenish cast. The nozzle check showed a good gray for the black ink, but I still got a green overtones when I printed the picture. Then black stopped completely on the nozzle check. I did two cleaning and two deep cleanings but still no black on the nozzle check. Now the picture itself prints out with a very uniform purple background and the nozzle check still shows no black ink.
  • carolrogovin Jul 25, 2009
    NO, I STILL HAVE A PURPLE BACKGROUND
    DEAR nL INKED,
    HOW WE CAN PROCEED TO SOLVE MY PROBLEM. DID YOU GET MY RESPONSE? --WHICH WAS: THAT I HAVE ACTIVATED ALL THE GRAYSCALE SETTINGS, BOTH AS A PRINTING PREFERENCE AND WITHIN THE PRINTER SETTINGS FOR THIS PICTURE. HOWEVER THAT DID NOT CHANGE THE PICTURE--STILL NO BLACK BACKGROUND. I HOPE YOU LIKE A GOOD CHALLENGE. THANKS FOR YOUR HELP. (IF YOU ARE BOWING OUT, WILL YOU LET ME KNOW?)
    --CAROL
Hi there
Sometimes, printers use colors from the other cartridges in order to form a deep black colour. It does seem that not enough pure black ink is getting onto the paper.
Can you check that there is enough black ink remaining? If so, go to the print options of the program from which you are trying to printer the image, and set the colour output to black or greyscale only. This may be within an option called Printer Preferences from the Print dialogue window of the program from which you are printing from.
Then, print an image as a test and see if it comes out in black only this time.
I look forward to your reply.
Regards
Posted on Jul 25, 2009
Canon Pixma IP4600 won't print black on disc but will print black alright on paper.
go to http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4600#ServiceAndSupport
Oct 28, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
How do I print a negative black & white photo...it keeps printing a yellow tone image?
hi...while you give the printing command go to option and select black and white option. u can get black and white.
If u get yellow tone image means that the catridge of black might hav finshed please check the catridge and replace it.
Jul 05, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
How do i change the print dpi on my canon ip4600
That is changed in your printing software and will depend on how the image was saved to your computer. You can't print at higher DPI than image was saved in.
Dec 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon Pixma iP4600 not printing cyan
I had the same problem and I finally FIXED IT. I first tried replacing cartridges - no good, I then took the print head out, dismantled it and washed every component, no good. I then noticed that there were small streaks of blue on the paper when I tried to print a blue image so I worked out that the blue ink is getting through, but very slowly (yours might not be getting through at all but don?t worry this should still fix it). So I got a very thin pin and pushed it into the cyan pad on the print head creating a thin channel for the ink. Tried to print again, perfect, blue now working. Hope this helps - remember, you do this AT YOUR OWN RISK, there is no guarantee this will work for you, it worked for me but there is the obvious risks that you may break your printer. I did it because it was broken as far as I was concerned and I had nothing to lose if it broke completely, you must make that choice yoursel
Aug 25, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
I want to print on a CD using a Canon Pixma iP4600
hi,
1. to print on a cd, there is a (cd sticker paper) available in the market, buy it and feed it in your printer...
2. to print on a cd, you should have special software such as... Nero Burn version 5.0/5.5/6.0/6.5/7.0,
this is a cd burning software, in this software you will find sticker designing option, where you can
select images or text to design the cd for printing..
Jun 21, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
536 people viewed this question
k24674
jasbo
jasbo
