Question about Stihl Garden
How do I check the compression of my stihl km90 engine
    Visited the website for 30 consecutive days.
  • 110 Answers
Remove the spark plug, spin the compression tester into the spark plug hole, hold the throttle wide open and pull the cord 2 or 3 times. Look at the reading and compare it to specifications... Your lawn and garden store may be able to do it for you or may know someone who can. Hope this helps.
Posted on May 12, 2017
    Top Expert:
  • Stihl Master
  • 77,932 Answers
Pull the spark plug out and hook up a compression test meter.
Do you have parts breakdown schematic showing internal parts of engine?
I have a pdf file service manual but it won't let me send on here, if you want I will email it to you...and here is a YouTube link to cleaning that engine...sent one page of manual, but its 52 pages or iwould send the rest on here
Stihl 009 Chainsaw Repairparts-breakdown-schematic-showing-lssthgpi25gedqz0c32oowfn-1-2.png
Sep 18, 2015 | Stihl Garden
Stihl weedeater stalls when I compress throttle trigger
dump the fuel --clean air filter-change spark plug-- use new fuel synthetic 2 cycle oil--93 octane
Oct 11, 2014 | Stihl Garden
Why does my stihl chainsaw spray gas out muffler and carburator
I had something similar a long time ago with my Stihl chainsaw. I removed the small carbeurator and found that the gas/ carb float was at times sticking in the open position allowing too much gas to flow into the piston cylinder. The spark and compression can theoretically burn so much fuel on each compression stroke of the piston and the residual ie; overflow of gas/oil mixture is forced out the muffler on the exhaust stroke. Keep in mind the engine is a two cycle stroke engine meaning it fires each time the piston compresses and therefore if it is the float sticking open it will seem like a great deal of raw fuel being forced out the muffler. I hope this will give you a starting point to look at. Good luck and hope you don't get discouraged because the Stihl product, especially the chainsaw is one of the finest produced and on the market today.
Aug 02, 2014 | Stihl Garden
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl blower will not start
check your abc's of engines first
(intake,fuel) substitute a tiny amount of raw gas in carb intake to see if it springs to life !
(compression) -pull rope slowly to "feel" the piston move up in cylinder to meet resistance , then down again
(combustion,spark) - remove spark plug from engine and place nearby the hole (don't hold it !!!) and pull saw over briskly look for spark near tip of plug
Dec 28, 2013 | Stihl 18" Chain Saw Bar 3005 008 4717
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
The KM90 is a 4 mix engine and regularly needs the valve clearance tightening up, remove the orange housing, under there you will see the rocker cover, held on by 1 screw. The valve clearance tool can be bought from your local dealer or online.
Jun 30, 2012 | Stihl Garden
I have a 026stihl that won't start
It would be a good idea to check the compression first to make sure there is enough to make the saw run. A person can run in circles trying to figure out an issue if the compression is below 100 psi, there should be about 150 psi. Older Stihl saws are also notorious for cracked fuel lines. Check the fuel line to be sure it is ok, also check the spark.
Aug 04, 2011 | Stihl Garden
Garden Logo
54 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
