Question about Garden
My JDF510 blades won't engage.Relay has been replaced. Switch to engage doesn't start blades.
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 138 Answers
SOURCE: pto not engaging blades
Lets start from the beginning:
Do you have power going to the switch you need to check this with a volt meter it should read between 12 and 13 volts with thew engine off
if you have power to the switch next we need to check to see if there is power coming out of the switch again check with a volt meter.
if you have power coming out of the switch then we need to see f power is getting to the relay on the battery terminal and the switch terminal and if there is power to both terminals then we need to see if the relay is functioning correctly ( check output terminal with voltmeter)
If we have power to and through the relay we need to see if we are getting power to the clutch ( check this at the clutch) if there is no power to the clutch trace your wires back until you find power and make the repair. If ther is power to the clutch but the clutch does not engage you may have an open ground meaning the circuit is not complete again check your wiring. If everything checks out but the clutch does not engage then you have a bad / open in your clutch hope this helps
Posted on Aug 21, 2009
  • 68 Answers
SOURCE: replaced starter relay and stater in yamaha 1100 2001 v star
Charge battery to full, start in neutral, still clicks? Bad ground, or bad connection. Jump starter solenoid with screwdriver,etc. if motor turns over the relay is bad. Chaz Moto DC
Posted on Jan 22, 2010
  • 640 Answers
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Posted on Aug 07, 2011
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
Husqvarna yth 170 problems when engage blades clutch nothng happens
On the 170 there is an electrical clutch that enables the blades to engage. This of course is an important safety feature.
If the operator is not sitting in the seat the switch located beneath the seat will not actuate. It is possible that the weight of the operator is insufficient to activate the switch. Other possibilities are the connection to the switch has become disengaged, or the switch has failed.
There are other possibilities of why the blades do not engage but I would evaluate the seat switch first and the relay (operator presence relay) that the seat switch activates second..
Nov 28, 2015 | Husqvarna Garden
Why don't the blades engage when I pull the start handle?
your switch or safety switch or pto are bad,you also think that we are mind readers
Jul 29, 2015 | Garden
Blades wont engage
Check for power to the clutch from the switch or could be a bad relay
Jun 16, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My serger won't cut
Sounds like your blades are either dull, misaligned, disengaged or broken. Examine your serger book for how to re-engage the blades. If they are engaged, make sure they are aligned correctly. If that still doesn't help check for damage.
Sep 10, 2012 | Brother 925D Serger
Ajust clutch
sounds like a bad relay or a safety switch start with the switch under the seat
May 07, 2012 | Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
