Question about Sony Televison & Video
MY SONY TV HAS LOST SOUNG - Sony Televison & Video
Samsung hlt5087 sax soung but no picture.
I have a 36inches Samsung LCD TV. When it is on there is no picture but all control is working...what is the possible problem of my Tv
Sep 29, 2013 | Samsung HLT5087SAX 50-Inch Slim LED Engine...
Crt tv pictur but no soung
Check its speaker and sound settings first. If sound is muted in the settings, there will be no sound from the TV. If these are all found OK, check and replace damaged component/s at its audio output section circuit.
May 14, 2013 | Samsung Televison & Video
transfer case is in neutral
Jan 20, 2013 | 2005 Dodge Durango SLT
Lost the remote for my 42" sony Flat TV
You can get a universal remote, Logitech makes some great ones that make controlling multiple systems easy. You can also find the model of your tv and try to find a replacement remote either through sony or perhaps another retailer.
Mar 04, 2011 | Sony Televison & Video
Rattling soung after changig timing belt of Mazda
light metalic pinging type noise check for loose heat shield and pipe clamp, if not could be few things need more info
Jul 06, 2009 | 2003 Mazda Protege
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
